whats wrong with my knock sensor for my 97 civic ex
ok there this problem with my knock sensor.... everytime i use my obd II to turn it off. it looks ok...but when i start to drive it and once it hit over 40mph the check engine turns back on... whats with that? so i keep repeating it but it keep doing the same thing so was wrong with it? help please?
read my signature.....
what do you mean "turn it off with your obd II"? if you have a check engine light for a knock sensor you need to replace the knock sensor, not just reset the light.
if you are detonating causing your knock sensor to retard your timing you need to take care of the cause of detonation before meltdown.
