(help need) i dont have a jumper harness is there any other way to check for codes
Old Oct 1, 2007 | 07:58 AM
hotxcivic92's Avatar
Default (help need) i dont have a jumper harness is there any other way to check for codes
i have a 92 dx civic hatchback that is in limp mod and there is no jumper harness on it is there a eather way to check why it is in limp mod can some-one help me
Old Oct 1, 2007 | 08:01 AM
Kegan's Avatar
Limp mode usually means ditributor. Reset your ecu and see if it corrects it even if only for a minute. Then bolt on a known good dizzy and see if that fixes that ish.
Old Oct 1, 2007 | 08:04 AM
Default Re: (Kegan)
so what dose dizzy mean is just a code b/c i have a b16a with a d16/y8 distrubutor but it fired up the car and everthing so i though nothing about it seem everthing was right you no
Old Oct 1, 2007 | 10:03 AM
Kegan's Avatar
Dizzy means ditributor.
Use a distributor for the motor and you won't have the problems, yeah it'll start the car but it won't run it the way you want it to.
Old Oct 1, 2007 | 10:10 AM
pdiggitydogg's Avatar
Default Re: (Kegan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kegan &raquo;</TD></TR><TR><TD CLASS="quote">Limp mode usually means ditributor. </TD></TR></TABLE>
...What You could be throwing any number of codes that throws the ecu into "limp" mode.
bottom of this thread:
https://honda-tech.com/zerothread?id=2029482
http://technet.ff-squad.com/wiring.obd1.htm
Old Oct 2, 2007 | 07:56 AM
Default Re: (Kegan)
ok ill have to go out and by one and then let you no how it went
Old Oct 2, 2007 | 08:02 AM
The right distributor is important.....but you need to do what I provided to check the code.
Old Oct 2, 2007 | 08:14 AM
Default Re: (pdiggitydogg)
i cant check for any code i dont have a jumper harness in my car wish there was a eather way
Old Oct 2, 2007 | 08:22 AM
like i looked where it should have been but it is not there and i dont no what to do i have the pin out schematics but now what do i do?
Old Oct 2, 2007 | 08:35 AM
Max Kling's Avatar
Just find the wire on the ECU to trip the self diagnostic and ground it. You dont need just the jumper.
EDIT: pdiggitydogg did all the work for you, its the white wire on pin D4 ground it.
And dont listen to the guy who said it was the distributor. CEL's rang from 100's of thing, distributor is only like 5 of them. Also dont throw parts at it, figure out whats wrong first then fix it right, dont just throw a new distributor on unless its causing the problem.
Old Oct 2, 2007 | 08:36 AM
I put two links in my first reponse....you need to read what I said first...then look at the first link...followed by the second...
Old Oct 2, 2007 | 08:44 AM
so just ground out the d4 with is the scs service check single now dose it matter what i ground it to or is this not right b/c that is what you guys made it sound like
Old Oct 2, 2007 | 08:46 AM
A ground is a ground
just run a wire from D4 to a clean bolt, the chassis itself...whatever
Old Oct 2, 2007 | 08:47 AM
Default Re: (Max Kling)
hell yea i have so much money in parts that i dont even need just bought a new ecu for my b16 i had a chipped skunk2 p28 but now i have a stock b16 ecu and you no how much they can be not to cheap tired of spending money on **** that dont fix it
Old Oct 2, 2007 | 09:29 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Default Re: (hotxcivic92)
you can either use a paperclip, or go to autozone and borrow their OBD2 tester for free.
Old Oct 2, 2007 | 09:41 AM
luvmihatch's Avatar
Default Re: (Vindicator9000)
mac.. stop being gay and use the schematic he showed. u ... and the car is obd1 rite... if u need me to i can come over and c if i can hook any thing up from my car just call me...
91whitecivic
Mar 6, 2011 10:06 AM
hotxcivic92
Oct 1, 2007 07:55 AM
93slmdcvcsi
10
Jul 19, 2004 05:02 AM
simplestyles
Mar 4, 2004 01:54 PM
GumballNA
Aug 14, 2003 11:32 AM
