HELP!! jumper harness question for OBD2-1... ??
Old Aug 12, 2003 | 12:19 PM
GumballNA's Avatar
Default HELP!! jumper harness question for OBD2-1... ??
ii have a 97 dx (ej6) and i just purchased a p06 ecu.. (OBD1 92-95) and i have going to covert my d-series to obd1... instead, since i have only 1 o2 sensor....
A buddy of mine did the exact same thing! and it threw up IACV code... not sure the number.... but if that happens to mine how do i fix it??? he just leaving his be...
Old Aug 12, 2003 | 02:51 PM
GumballNA's Avatar
Default Re: HELP!! jumper harness question for OBD2-1... ?? (Type-X)
I just ran it right now, and it ran horrible!
When i start the car it bog's down to like 200rpm, and it is sputering horribly! when i make a turn and downshit into 2nd, it come's so close to dying, im surprised it didn't.
I want to get this fixed... what can i do to the IACV to fix it!? i need help really bad.. please someone help.. espcially if u can answer me soon!
Old Aug 12, 2003 | 05:38 PM
nasteboyii's Avatar
get a new iacv, also check the codes to make sure its A IACV code, and not something else, besides that, good luck
dan
Old Aug 12, 2003 | 06:44 PM
GumballNA's Avatar
Default Re: HELP!! jumper harness question for OBD2-1... ?? (nasteboyii)
i don't think i need a new IACV, because when i put my stock ECU back in, it run's just fine!
But when i run the p06 with the convsersion harness... it almost die's.. and it just sound's horrible...
I do know that the p06 92-95 has a 2-wire IACV just like the b-series...
Old Aug 12, 2003 | 09:45 PM
GumballNA's Avatar
Old Aug 13, 2003 | 07:04 PM
GumballNA's Avatar
YOU HAVE GOT TO BE ******* KIDDING ME!!! NOT ONE ******* PERSON ON THIS SITE HAS A SOLUTION TO THIS PROBLEM!! AND U CALL YOURSELVE"S HONDA TECH'S!! sheesh!
Old Aug 13, 2003 | 07:10 PM
Skyllz's Avatar
1- writing all in caps will only get you in trouble...
2- you already have your solution to your problem, you said it earlier... 3 wire IACV on a 96-98 D16Y7 your P06 runs only 2.
SO, you need to convert your intake to a log style instead of a top draft throttlebody like an intake from an ex or a 92-95 DX.
Old Aug 13, 2003 | 07:23 PM
GumballNA's Avatar
Default Re: HELP!! jumper harness question for OBD2-1... ?? (Skyllz)
thank u! i was only questioning a theroy.. not actually making a statement.....
So i actually have to get a EX intake now... to make this work?
Old Aug 14, 2003 | 02:38 AM
Skyllz's Avatar
that would be the best way to do it.
do not forget to repin the IACV at the ECU also as per katmans diagrams, search and you shall find them, I dont have them handy.
Old Aug 14, 2003 | 03:12 AM
Blown90hatcH's Avatar
Default Re: (Skyllz)
https://honda-tech.com/zerothread?id=558245
Old Aug 14, 2003 | 11:32 AM
GumballNA's Avatar
Default Re: (Blown90hatcH)
i already have katmans diagrams, thank u.
Im not even going to worry about it if i end up having to get a ex intake mani.
Because i am planning on doing a swap down the road. so that would be pointless.
ZombiePharoh
Engine Management and Tuning
Mar 29, 2012 02:12 PM
hatchdrvr
Dec 12, 2011 06:50 AM
darrinbrewer
Sep 20, 2010 01:12 PM
beseman
Aug 24, 2006 10:18 AM
