Cold start problem
Old Sep 30, 2007 | 05:33 PM
bballdude's Avatar
Default Cold start problem
When the outside temperature is below 45º, my car wont start. The engine turns but it acts like it's not getting any fuel. When it gets warm outside, it starts just fine. It has a new battery so thats not the problem.
It's a 1989 automatic Civic LX..
Modified by bballdude at 10:50 PM 9/30/2007
Old Sep 30, 2007 | 09:58 PM
vicivicvic
Guest
Posts: n/a
Default Re: Cold start problem (bballdude)
Does it always happen in low temperatures or is it random?
Old Oct 1, 2007 | 12:47 PM
The_Undertaker's Avatar
75.168.105.221
Is that new battery the right one? Does it have the correct cold cranking amps? It should be rated at 410 CCA. Could be something else like the ingition switch or the rotor inside the distributor. First i check the battery if the right one for your cars needs. Good luck man.
Old Oct 1, 2007 | 12:54 PM
SIred91's Avatar
Rainman
Default Re: (1988hondacrxsiR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 &raquo;</TD></TR><TR><TD CLASS="quote">Is that new battery the right one? Does it have the correct cold cranking amps? It should be rated at 410 CCA. Could be something else like the ingition switch or the rotor inside the distributor. First i check the battery if the right one for your cars needs. Good luck man.</TD></TR></TABLE>
Your battery info is total horseshit. You need to learn more and post less.
Old Oct 1, 2007 | 01:22 PM
vicivicvic
Guest
Posts: n/a
does it also not start when you are in a 45º parking stall?
Old Oct 1, 2007 | 01:41 PM
SIred91's Avatar
Rainman
Default Re: Cold start problem (vicivicvic)
you just don't quit do you?....^^
Old Oct 1, 2007 | 01:43 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">
Your battery info is total horseshit. You need to learn more and post less.</TD></TR></TABLE>
But he has teh Alldataz!
OP, do you get any CELs when it doesn't start? It could be an IACV issue.
Old Oct 3, 2007 | 05:46 PM
konka's Avatar
Default Re: (wiZCo)
i had that problem b4. well i think i mught be the same. when u keep the key on the ON postion and just let it crank does the care eventually start? if so check your temperature sensors. one of my wires broke off and i couldnt start it at -5c or less. had to plug the car up at night. never had to do that in my life. but check that and let me no.
love_my_ekcoupe
Jan 26, 2010 08:20 PM
dvlsfan30
Oct 21, 2008 05:09 AM
jdmkrazie
Nov 22, 2005 07:15 PM
Tee Jay
11
Oct 26, 2005 03:16 PM
1.8
Dec 3, 2004 08:17 PM
