cluster problems speedometer, rpm, fuel and temp does not work !!!!!!!
cluster problems speedometer, rpm, fuel and temp does not work !!!!!!! but light up
every things lights up but nothing works be sides hazards and lights icon (they blink when there on thats what i mean)
speedometer, rpm, fuel and temp do not show but light up
my radio and a/c and heat switches work as well light up
what can be the problem???????
It has to be a fuse or bad ground or something. Have you at all recently worked on anything electrical in your car? such as install new electronics? Or an alarm? Basically anything that would cause for you to be working on your car's wiring (as well as add your own)
Well only way to tell if its fuse/wiring related, or just the cluster is to find a friend or someone you can trade clusters with just to see if it works or doesnt work.
Did you make any changes recently - a new gauge cluster, a new distributor or VSS - or did this just start happening to the stock cluster?
This is a question that you should have answered in your first post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">Well only way to tell if its fuse/wiring related, or just the cluster is to find a friend or someone you can trade clusters with just to see if it works or doesnt work.</TD></TR></TABLE>
start with that. then go from there
From what i think, its got to be your Cluster that has issue...probably burn up somewhere inside the cluster...swap it out and see what happen next if thats the cluster that was workin before....since u said its not your fuse from the inside dash....its seem too many issue for fuse but i can be wrong too....but try to swap your cluster out first i would do...??
Did it just all of the sudden stop working???
Modified by civiccoupegsr at 2:28 AM 10/9/2007
2LGSR
Oct 7, 2010 08:35 PM
jdmoutkast
13
Jun 30, 2004 11:50 PM
