turbo?????????????
turbo?????????????
i jus put a complete motor in my 95 civic b18a1 turbo out or a 90 ls it is turboed garret t3/t4 turbo is it bad to drive it without tuning it ???????
Re: turbo????????????? (95civiccpdx)
Bad doesn't quite say it.
Horrible is more accurate.
Remove the charge pipe and set the wastegate to 0psi until you get it tuned.
Re: (95civiccpdx)
is there a chance you can get hondata s300 ver and tune it yourself?
(that's a good question by 95civiccpdx)
i would like to know more on this myself
Now that i think of it, if you dont want to run the turbo for the moment but dont want to completely uninstall it, is that possible without damaging anything? would you just disconnect the charge piping, use the piping on the TB side as an intake, and set the wastegate to 0psi and let the exhaust gas run through the downpipe??
Re: (iVteC_PoWeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civiccpdx »</TD></TR><TR><TD CLASS="quote">the guy thats gonna tune it wants $1000.00 jus to started and then it may be higher i think thats a lil crazy to tune a civic
$1000 is ridiculous if that does not include something like hondata in the cost.
$400-$600 is more accurate, usually closer to $500.
Re: (iVteC_PoWeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR »</TD></TR><TR><TD CLASS="quote">Now that i think of it, if you dont want to run the turbo for the moment but dont want to completely uninstall it, is that possible without damaging anything? would you just disconnect the charge piping, use the piping on the TB side as an intake, and set the wastegate to 0psi and let the exhaust gas run through the downpipe??</TD></TR></TABLE>
You mean pretty much exactly re-typing what I said?
Yeah, you can.
Yeah, you can.
Re: (forcefedferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forcefedferio »</TD></TR><TR><TD CLASS="quote">
$400-$600 is more accurate, usually closer to $500.</TD></TR></TABLE>
Yes, the guy that wants to tune his car for 1k is obviously in the ***-raping business.
Don't take your car to him - should only take between 2 and 600 for a full tune. Usually about 100-200/hr - a Honda isn't exactly rocket science to tune.
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">You mean pretty much exactly re-typing what I said?
Yeah, you can.</TD></TR></TABLE>
Yes-sir lol.
Any chance of damaging anything?? I was thinking Id have to install a whole setup and make sure its running properly the same day
Yes-sir lol.
been there done that
Re: (iVteC_PoWeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR »</TD></TR><TR><TD CLASS="quote">Wouldnt setting it at 0psi and removing the spring be basically the same thing? Or im guessing theres less of a risk with just removing the spring. </TD></TR></TABLE>
the spring dictates the lowest boost setting possible. so for instance if there's a 7psi spring in there that's as low as boost will go.
ight guy a good freivd of mine hooked me up with his boy in philly hes gonna tune my car on chrome for 250.00-350.00 thanks for the advice i think im gonna get it towed there so i dont mess nuttin up ....... listen i got an obdo 1.8 does any one kno if an obd1 thermostat housing will bolt up to the obdo bcuz obdo has no senser n my fan doesnt come bcuz of it????
