Bad wiring- turn signals, clock, and cluster gauges don't work
Alright so first comes first. The previous owner of the car did some hack jobs on the car just pulling power from anywhere, having higher amperage fuses everywhere, and using butt connectors all over for god knows what instead of soldering. So I replaced all of the fuses with the right amperage. Everything worked when I turned the key on the first time. Then I use the turn signal and then it works okay then a couple seconds later it goes alot slower then finally stops working. The entire cluster doesnt work. The fuel was working then slowy went to the bottom then never worked. So at this point the turn signals dont work at all, the clock, the cluster doesnt read anything but all the lights work like the cluster light, interior light and ac lights up. What I noticed when I pulled every fuse to c if anyone was blown the radio-cigarette lighter 15 amp fuse is blown. Its the only one. I noticed every time I click the key to the on position I can hear it blowing right when I turn the key. So what all do i need to do . Is there a short or something. And also do i need to get a turn signal relay? Im not to electrical savy. Sry for it being so long Its just been driving me ****ng crazy forever. Thank you for ur help
Re: Bad wiring- turn signals, clock, and cluster gauges don't work
If you hope to get useful replies, then provide all relevant information about your car and engine:
https://honda-tech.com/forums/showpo...48&postcount=2
EGed up from the seat up
03-04-2009 04:13 PM
sohcvtec1995
10
07-08-2005 06:31 PM
yeegsr
06-28-2005 10:40 PM
Dancing is Forbidden
09-03-2003 11:25 AM
