compression test lsvtec
Old Sep 21, 2007 | 11:19 AM
sheBangZ's Avatar
Default compression test lsvtec
I'm just wondering if this sounds normal. Ls block, p30 pistons, stock b16 head. compression test yields 165 160 170 155. The numbers itself sounds low for the build. Motor still runs strong and does not burn any oil. Is there an explanation for this. Car was not warmed up when this was done.
Old Sep 21, 2007 | 11:37 AM
fmrprojects's Avatar
Default Re: compression test lsvtec (sheBangZ)
you should warm it up first and have the throttle wide open when doing the compression test. my old lss vtec with pr3 pistons was 265 all across
Old Sep 21, 2007 | 11:39 AM
97Ej6mike's Avatar
Sounds like your right on target
http://autos.yahoo.com/maintai....html
Old Sep 21, 2007 | 11:43 AM
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like your right on target
http://autos.yahoo.com/maintai....html</TD></TR></TABLE>
it should be a bit higher cause the pistons has a higher dome than the stock. i can see a stock ls block would read 160. i put together stock ls vtec and b20 vtec that reads 180psi
Old Sep 21, 2007 | 11:50 AM
about:blank's Avatar
Old Sep 21, 2007 | 12:00 PM
sheBangZ's Avatar
i was expecting it to be at the min. 220, all seein that its puttin compression out to over 11's.
Old Sep 21, 2007 | 05:15 PM
sheBangZ's Avatar
bump
Old Sep 21, 2007 | 05:22 PM
efking1985's Avatar
well my jdm single cam is putting down 210 in a cylinders is that good?
greasemonkeys
Jun 21, 2005 09:19 PM
rough_draft
May 26, 2005 12:23 PM
lke2drvgsr
17
Jan 17, 2004 12:44 PM
Triple T
Feb 10, 2003 03:32 PM
