sensor question?
Old Sep 19, 2007 | 08:05 AM
hondaon18's's Avatar
Default sensor question?
okay so i was taking out the b16a out of my buddies crashed civic. and when i got it out with the engine hoist the engine jerked and crushed my sensor that is connected to the throttle . not the map sensor but i thinks it is the throttle position sensor. any way do i need to get a sensor from a b16 or can i use any throttle sensor from a single cam or does it have to be exactly from a b16a?
Old Sep 19, 2007 | 08:10 AM
philosofy1's Avatar
Default Re: sensor question? (hondaon18's)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaon18’s &raquo;</TD></TR><TR><TD CLASS="quote">okay so i was taking out the b16a out of my buddies crashed civic. and when i got it out with the engine hoist the engine jerked and crushed my sensor that is connected to the throttle . not the map sensor but i thinks it is the throttle position sensor. any way do i need to get a sensor from a b16 or can i use any throttle sensor from a single cam or does it have to be exactly from a b16a?</TD></TR></TABLE>
not to sure if one from a d-series would fit, but any from a b-series would.
Old Sep 19, 2007 | 08:18 AM
Default Re: sensor question? (philosofy1)
damn but they look the same size and length . how much do does sensors go for
Old Sep 19, 2007 | 08:32 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaon18’s &raquo;</TD></TR><TR><TD CLASS="quote">damn but they look the same size and length .
if they do, try it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaon18’s &raquo;</TD></TR><TR><TD CLASS="quote"> how much do does sensors go for
alot, i search one of the dealer threads earlier when i fisrt posted. they don't even have a listing for it. you know what they say, if you have to ask for the price it's expensive.
Old Sep 19, 2007 | 09:39 AM
Relic1's Avatar
TPS - http://cgi.ebay.com/ebaymotors...61363
Old Sep 19, 2007 | 09:45 AM
Default Re: (Relic1)
man i need one like now and i called honda and they gave me a price of 184 dollars
Old Sep 19, 2007 | 09:48 AM
Default Re: (hondaon18's)
okay it says that it will work with any honda or acura engines so does that mean that the one that i have will work for my b16 or is that just a typeo so they can sell that sensor
Old Sep 19, 2007 | 09:54 AM
pdiggitydogg's Avatar
sensors are the same D:B - interchangeable.
you DO need a multimeter to install it correctly...you cant just slap it on and call it quits - you need to wiggle it around to get each pin into spec
Old Sep 19, 2007 | 10:03 AM
Default Re: (pdiggitydogg)
so do i need to have the car on to wiggle it around and how would i now if im doing the wiggling right
Old Sep 19, 2007 | 11:55 AM
anyone how do you take out the tps sensor if the screws are cut off? how do i take it off with out messing up the tps sensor
Old Sep 19, 2007 | 03:38 PM
you can cut the the rivets off (heads) or try cutting slots into them and back it out with a screwdriver.
like i said, you need a multimeter to see the readings on each pin, with the throttle closed - it reads throttle position, afterall
readings will change when its moved around on the TB
cryingsuns
Mar 20, 2011 01:13 PM
ef9_civic_hatch
May 13, 2007 03:50 PM
B!^A@
Aug 10, 2006 09:17 PM
Ignitecivic
Nov 13, 2003 02:50 PM
DKay04
Jun 28, 2002 01:31 AM
