b16a sirII Map sensor...where is located?
ok...its a jdm b16a sirII. Theres no map sensor on the throttle body or on the firewall. I swaped it in a cx hatch. maybe the cx d15 had it on the throttle body so when that was removed so was the map sensor?? I think this is way my vtec isnt working and im thorwing code 3...
there should be a hose coming off the TB, remove that map from you cx and connect it to that hose and plug in the map sensor and you will be set. zip tie the map to the firewall. my b16a is the same way and it run perfect
gl
gl
no map sensor. so all i gotta do is get a map sensor from which civic? then plug it in and connect the hose? you talkin about the little brass tube stickin outta my throttle body right?...thats the only tube thats not hooked up to something
yea the map is on ur old tb. b16a's had the map on the fire wall thats y u didnt notice it missing
just find ur plug and hook it up to that brass nipple on the tb, easy fix and will run much better
btw ur old map will work just fine, when u pull it off the old tb u will see the nipple on it as well
sweet thanks guys for all the help! i already sold my d15 but i have already located one from a buddy and ill try it 2marrow. You think thats why my vtec isnt workin?
Another question, why is there some people sayin there jdm b16's had a map sensor on the tb and some say they didnt have one. iv had a b16a2 and that map sensor is on the tb? can someone explain which jdm b16's had and didnt have it on the tb? thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Endo-land »</TD></TR><TR><TD CLASS="quote">The 92,93 had it on the firewall. The newer ones had them on the throttlebody.</TD></TR></TABLE> exactly, 94,95 was on the tb.
cool thanks guys! i bought a map sensor and installed it on the firewall 2day. hooked it up and it runs WAY better. But still no vtec. IM still so confused! cel's are 14 22 21.
velisma
Feb 6, 2009 06:08 AM
gsxr1k05
Jan 15, 2007 12:58 PM
