Question about spools
Old Sep 18, 2007 | 05:33 PM
vtec4max's Avatar
Default Question about spools
I know that spools are used to lock axle shaft together. Is it a bad or good idea to just throw in a spool instead of LSD to a tranny? what would you guys recomend? T.I.A.
max
Old Sep 18, 2007 | 06:00 PM
4g hatch's Avatar
Default Re: Question about spools (vtec4max)
there a cheap alternative but there for total track use. the steering is to screwy for the street
Old Sep 18, 2007 | 06:08 PM
NJIN BUILDR's Avatar
The biggest drawback is if you break an axle you instantly get all your power to the other wheel.That can mean over the centerline or into the wall.But at least if you don't crash you can still drive into the pits.And you will break driveline parts driving on the street.
Old Sep 19, 2007 | 05:27 AM
mgags7's Avatar
skidding tires around every corner = bad idea.
positraction ftw
Old Sep 19, 2007 | 04:09 PM
vtec4max's Avatar
ok, thanks a lot guys. I guess LSD is preferred then.
nextproject97
Transmission & Drivetrain
Apr 6, 2009 06:47 PM
champLSinteg
May 24, 2007 08:11 AM
jep
Jun 12, 2006 02:55 PM
2bars
Dec 11, 2004 08:21 PM
chrisJ
May 7, 2003 03:02 PM
