ATS lsd question
Old Apr 17, 2003 | 02:20 AM
chrisJ's Avatar
New User
Default ATS lsd question
my ats 1.5way lsd is sheering off the axle splines on the passenger side and causing the axle to pop out, even under street driving conditions (turning) and obviously more often at the track. change the lsd oil regularly, and it seems to be functioning fine other than sheering the splines. anyone have an idea what might be causing this or have heard it happening before+
Old Apr 17, 2003 | 04:09 AM
1GreyTeg's Avatar
Default Re: ATS lsd question (chrisJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisJ &raquo;</TD></TR><TR><TD CLASS="quote">my ats 1.5way lsd is sheering off the axle splines on the passenger side and causing the axle to pop out, even under street driving conditions (turning) and obviously more often at the track. change the lsd oil regularly, and it seems to be functioning fine other than sheering the splines. anyone have an idea what might be causing this or have heard it happening before+</TD></TR></TABLE>
Before you start some huge debate or any finger pointing or an ATS rag session please contact who sold it to you, or Yasu or Chris (aka rodney here on HT) them selves.
Nothing against you, I just don't want this to sour and misinformation to be passed.
Best of luck,
A.
Old Apr 17, 2003 | 04:55 AM
Turtle's Avatar
Default Re: ATS lsd question (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">Nothing against you, I just don't want this to sour and misinformation to be passed.</TD></TR></TABLE>
I agree, a lot of people will go "oh no, I can't get an ATS now!" ATS is a company and they make quality parts. ATS is awsome in my book and I agree Yasu will be able to make it right if you have any problems.
Old Apr 17, 2003 | 06:03 AM
chrisJ's Avatar
New User
Default Re: ATS lsd question (Turtle)
in no way pointing fingers or blaming the product. i love the way the lsd performs on the track and highly recommend ats products in general. i have contacted ats japan and didnt get much to go on as far as finding the source of the problem. just seeing if anyone has heard of this on that side of the pond or if its possibly user (me) error.
Old Apr 17, 2003 | 07:52 AM
JeffS's Avatar
http://www.a-t-s-usa.com
ATS USA INC
10 West Main Street, Suite 1-B
Elmsford, NY 10523
Phone: (914) 592-3990
Old Apr 18, 2003 | 06:14 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisJ &raquo;</TD></TR><TR><TD CLASS="quote">my ats 1.5way lsd is sheering off the axle splines on the passenger side and causing the axle to pop out</TD></TR></TABLE>
ok, first question: do you have the retaining ring (c clip) on the inside of the axle? if that ring is not there, the axle will walk out of the diff, allowing only half or less amount of splines to be in contact with the diff, basically putting mucho stress on them. secondly, what axles are thses? did you install a damaged axle, only to damage the diff spline now also? thirdly, who installed the diff? was it shimmed to proper spec? thanks. i love my ATS diff, and will not change it for the world. this is the first i have ever heard of these problems, and i have run these diff for years.
Modified by rodney at 10:42 AM 4/18/2003
Old Apr 18, 2003 | 06:22 AM
B18CXr's Avatar
Default Re: ATS lsd question (rodney)
ATS is a company
ditto
Old May 1, 2003 | 10:03 PM
chrisJ's Avatar
New User
1. yes the c-clip was on both axles that broke.
2. there were two sets of axles used, both undamaged as far as i know before we installed them.
3. we installed the diff and it was all done to proper spec.
i love the lsd as well and want to keep on using it, just want to pin point the source of the problem so i can fix it. here is a link to some of the pics if you are interested. anything else that might cause this?
thanks alot
edit: forgot the links
http://us.f1.yahoofs.com/users...y9VD3
http://us.f1.yahoofs.com/users...e6xx0
Old May 2, 2003 | 12:58 PM
PupaScoopa's Avatar
Did you use new c-clips or re-tension the old ones?
Maybe the diff carrier doesn't have deep enough grooves for those clips to seat in...
Old May 2, 2003 | 04:51 PM
chrisJ's Avatar
New User
Default Re: ATS lsd question (PupaScoopa)
the c-clips where not brand new. i guess i will look into that possibility more.
and just for an update, i have contacted both ats japan and ats usa, both say that the lsd did not cause the damage to the axles. any ideas on what could cause this to happen?
Old May 3, 2003 | 06:43 AM
Rodney's Avatar
if the axles were popping out of the diff, i honestly think the axles were not seated fully on install. are you from california? would you be the one that ran honda mtf in the tranny with the ATS diff?
Old May 4, 2003 | 04:28 PM
chrisJ's Avatar
New User
went thru two sets of axles. pretty sure they were fully seated. maybe that might be the problem. yes i am originally from CA, ATS fluid only since the diff has been installed.
Old May 4, 2003 | 06:09 PM
SuperTwinz's Avatar
This is the car:
This is the car pitting in when the axle popped out the first time (8 hour Endurance race).
Old May 5, 2003 | 04:36 AM
Rodney's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisJ &raquo;</TD></TR><TR><TD CLASS="quote">went thru two sets of axles. pretty sure they were fully seated. maybe that might be the problem. yes i am originally from CA, ATS fluid only since the diff has been installed. </TD></TR></TABLE>
the reason i ask about the seating, is because if they were not seated with the first install of the diff, there would be unnecessary stress on the splines (both the axle and the diff) and could have damaged the diff splines, thereforenot fully seating with the splines of the new axle. when you say the axles pop out, you lose fluid? the car stops moving? please describe, and pics of the axles and inside of the diff would be very helpfull. thanks.
Old May 5, 2003 | 05:47 PM
chrisJ's Avatar
New User
i understand your reasoning about seating the axle properly and it makes alot of sense. and hopefully is the culprit.
what happened was under turning the axle slides out of the differential, not completely, but enough that it is noticable and kinda scarry going thru turns. no fluid is lost tho, since it is still partially in the diff. the car will keep going tho. i linked pics of the axles on my previous post. so u can see the damage. dont have pics of the diff right now, but i will try to get those soon.
thanks alot for the help, really appreciate u taking the time to discuss this with me.
Old May 7, 2003 | 03:02 PM
chrisJ's Avatar
New User
up
nextproject97
Transmission & Drivetrain
Apr 6, 2009 06:47 PM
killrB
Dec 4, 2007 10:21 AM
deathofadam
30
Jun 15, 2007 05:13 AM
champLSinteg
May 22, 2007 11:38 AM
jep
Jun 12, 2006 02:55 PM
