94 civic hatch 205/40/17 tires rubbing in the wheel well
Old Sep 18, 2007 | 02:20 AM
djsire's Avatar
Default 94 civic hatch 205/40/17 tires rubbing in the wheel well
its rubbing in the back right wheel well when i have passangers or make left turns? any suggestions?
Old Sep 18, 2007 | 02:31 AM
hookedonponics's Avatar
Default Re: 94 civic hatch 205/40/17 tires rubbing in the wheel well (djsire)
I have the same exact problem in my 97 ex coupe but when I turn right. my car is dropped about an inch 1/4 in the front. i dunno.
Old Sep 18, 2007 | 03:24 AM
instrument's Avatar
seems pretty obvious to me
you either buy stiffer springs
put your shocks on a higher setting
or stop carrying chubby girls around in sets of 2's.
Old Sep 18, 2007 | 04:10 AM
PhoeNix007EG's Avatar
Default Re: (instrument)
LOL, thats what happens when you have fat girls in a honda. LOL
Old Sep 18, 2007 | 04:12 AM
djsire's Avatar
Default Re: (PhoeNix007EG)
haha.
yes my car is dropped in the front with skunk 2's
but its on the highest setting because of the h22 swap!
and no fat bitches . even though they give great neck lol.
Old Sep 18, 2007 | 05:10 AM
Scott.'s Avatar
maybe its cause your running 17's?
Old Sep 18, 2007 | 05:39 AM
djsire's Avatar
Default Re: (skittle_107)
so are you saying that none has succesfully ran 17's on there civic?
Old Sep 18, 2007 | 05:43 AM
instrument's Avatar
yeah, but i think 205 is a little wide for 17's on a honda.
i'm guessing most people with 17's might run something more narrow
Old Sep 18, 2007 | 05:49 AM
djsire's Avatar
like?
adn none answered why it would only happen on one wheel
Old Sep 18, 2007 | 05:51 AM
Probot's Avatar
Default Re: (djsire)
its simple dude...when you make turns weight shifts to the opposite side of the car...so if you rock fat bitches in the back (or just anyone in general) and turn like you're rally racing, its going to make the tires rub.
Old Sep 18, 2007 | 06:08 AM
djsire's Avatar
Default Re: (Probot)
slow turns and by myself,
still does it on pothole terrain.
and according to your explanation wouldnt it rub when i made turns either way?>\\
only one wheel rubs !!!!
Old Sep 18, 2007 | 06:47 AM
klungemonger's Avatar
There isn't anything narrower to run on 17's...205/40 is about the smallest you can get! The problem is, it's still 1" larger in diameter than stock so that's part of your problem, plus the 2" drop. Also it's not simply the overall width of the tire but the fact that with very low profiles the tire is kind of square rather than bulbous...in other words if you had a 205/60 on a 15" wheel the tire would be less likely to rub because the fattest part of the tire would be in the middle of the sidewall not at the tread like with the 40-profile. You know what I mean?
Old Sep 18, 2007 | 06:50 AM
97Ej6mike's Avatar
Face it, light is fast.
No fat chicks allowed
Old Sep 18, 2007 | 07:09 AM
94eh2's Avatar
Default Re: (97Ej6mike)
you need to roll your fenders
Old Sep 18, 2007 | 07:42 AM
H22Ej1's Avatar
Shenanigans
Default Re: (305accord)
i have 17s on my civic with 205s and its dropped low, but i have a very stiff suspension and my seats are gutted so fattys cant roll with me
Old Sep 18, 2007 | 07:47 AM
Syndacate's Avatar
Default Re: (H22Ej1)
You sure it's not the wheel bearing?
I don't care how you split it, it's not going to have ONE tire rubbing ALWAYS.
Old Sep 18, 2007 | 08:14 AM
Glockwork's Avatar
Default Re: (Syndacate)
roll your fenders
eastwood makes a good roller, and not too expensive
Old Sep 18, 2007 | 08:17 AM
djsire's Avatar
ok one more time.
from the top.
My by meself in the car.
left hand turns above 5 miles per hour
rear passanger wheel makes horrid noises.
i rolled the front passanger fender(which was making noise.)
and i attemted to roll the rear but i dont know how good a job i did scince the bat i used started falling apart,
when making right hand turns at any speed there is no noise.
i also hear noise when going over potholes at speed coming from the rear passanger side,
Old Sep 18, 2007 | 08:54 AM
BlackoutVTi's Avatar
Possible worn shock on one side. That's the only conclusion I'd jump to immediately, given your "one-sided" situation. I'm lowered modestly on 205/40/16's and, though it is on both sides, I still get a bit of squeek on spirited turns. How old are your shocks/springs?
Old Sep 18, 2007 | 09:42 AM
djsire's Avatar
Default Re: (BlackoutVTi)
dont know the might be original lol.
bought the car last year stock rears
Old Sep 18, 2007 | 10:11 AM
MattsGreenEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">stop carrying chubby girls around in sets of 2's.</TD></TR></TABLE>
haha ive had that problem b4
Old Sep 18, 2007 | 07:43 PM
djsire's Avatar
Default Re: (MattsGreenEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MattsGreenEG &raquo;</TD></TR><TR><TD CLASS="quote">
i usually strap them to the roof.lol
nah last week i had three chubby chix in the back and i caught a flat.
the girl actually said "Oh im sorry i know you caught a flat becasue were fat" lmao!
Old Sep 18, 2007 | 08:01 PM
blwn95civic's Avatar
why dont u just drive a couple miles then come back and pull the tire and see where inside the well its rubbing?? then go from there on wether its even rubbing or if it could be a wheel bearing
and if it is rubbing in the fender well, and your positive your car is sitting level, then just eliminate the spot in the fender well thats causing the problem and forget about it
Old Sep 18, 2007 | 08:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire &raquo;</TD></TR><TR><TD CLASS="quote">dont know the might be original lol.
bought the car last year stock rears</TD></TR></TABLE>
.....well you should check to see if it's really the wheel bearing, but it seems obvious to me that you may have one blown shock.
Timexlord
Dec 6, 2016 08:17 PM
eg6_danny
Feb 27, 2011 12:18 PM
blackbndt
Jan 3, 2010 03:59 PM
rathead81
Dec 25, 2006 10:29 PM
civiceg500
Jun 26, 2004 12:53 PM
