94 civic hatch 205/40/17 tires rubbing in the wheel well
its rubbing in the back right wheel well when i have passangers or make left turns? any suggestions?
Re: 94 civic hatch 205/40/17 tires rubbing in the wheel well (djsire)
I have the same exact problem in my 97 ex coupe but when I turn right. my car is dropped about an inch 1/4 in the front. i dunno.
Re: (PhoeNix007EG)
haha.
yes my car is dropped in the front with skunk 2's
but its on the highest setting because of the h22 swap!
and no fat bitches . even though they give great neck lol.
Re: (djsire)
its simple dude...when you make turns weight shifts to the opposite side of the car...so if you rock fat bitches in the back (or just anyone in general) and turn like you're rally racing, its going to make the tires rub.
Re: (Probot)
slow turns and by myself,
still does it on pothole terrain.
and according to your explanation wouldnt it rub when i made turns either way?>\\
only one wheel rubs !!!!
There isn't anything narrower to run on 17's...205/40 is about the smallest you can get! The problem is, it's still 1" larger in diameter than stock so that's part of your problem, plus the 2" drop. Also it's not simply the overall width of the tire but the fact that with very low profiles the tire is kind of square rather than bulbous...in other words if you had a 205/60 on a 15" wheel the tire would be less likely to rub because the fattest part of the tire would be in the middle of the sidewall not at the tread like with the 40-profile. You know what I mean?
Re: (Syndacate)
ok one more time.
from the top.
My by meself in the car.
left hand turns above 5 miles per hour
rear passanger wheel makes horrid noises.
i rolled the front passanger fender(which was making noise.)
and i attemted to roll the rear but i dont know how good a job i did scince the bat i used started falling apart,
when making right hand turns at any speed there is no noise.
i also hear noise when going over potholes at speed coming from the rear passanger side,
from the top.
Re: (djsire)
Possible worn shock on one side. That's the only conclusion I'd jump to immediately, given your "one-sided" situation. I'm lowered modestly on 205/40/16's and, though it is on both sides, I still get a bit of squeek on spirited turns. How old are your shocks/springs?
Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">stop carrying chubby girls around in sets of 2's.</TD></TR></TABLE>
haha ive had that problem b4
Re: (MattsGreenEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MattsGreenEG »</TD></TR><TR><TD CLASS="quote">
i usually strap them to the roof.lol
nah last week i had three chubby chix in the back and i caught a flat.
the girl actually said "Oh im sorry i know you caught a flat becasue were fat" lmao!
why dont u just drive a couple miles then come back and pull the tire and see where inside the well its rubbing?? then go from there on wether its even rubbing or if it could be a wheel bearing
and if it is rubbing in the fender well, and your positive your car is sitting level, then just eliminate the spot in the fender well thats causing the problem and forget about it
Re: (djsire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire »</TD></TR><TR><TD CLASS="quote">dont know the might be original lol.
bought the car last year stock rears</TD></TR></TABLE>
.....well you should check to see if it's really the wheel bearing, but it seems obvious to me that you may have one blown shock.
blackbndt
01-03-2010 03:59 PM
