whats the difference on chipping an ecu and chipping and dyno tuning ????????
hey guys....
i need your opinion on whats worth the money...
should i just get my ecu chipped for $75
or get it chipped and dyno tuned for $500 ???
whats the difference in hp??
hold on someone will answer it, you dont have to bump it every minute, i dont know **** about chipping yet im a noob sorry
uh lets see...
b18c5 itr block with gsr head
blox manifold
2.5 mandrel bent header back...
does it answer your question?
now can answer mines...
blox manifold
Ok if you read the link that doood provided you probally wouldnt need to keep bumping this thread. First off to There are alot of diffrent chips out there. Dont buy chips like skunk2 or spoon or mugen or crap like that off ebay. Usually all they do is up your rev limiter and remove the speed govenor. If you want to tune the car get your ecu chipped with something like crome, or you can go into Hondatat and all that, but for you I recomend crome. Now after the chip is installed you can either have a basemap burned on it or get the car tuned. A basemap can be anything from a map with factory settings or maybe the tuner has a map from a previously tuned car with similar mods to your own. This is a good way to free up some power and get the car running a little better. However, if you want the most power out of your setup as possinble after having the ecu chipped get it tuned. This way you can get the most power possible and make sure your A/F ratio is correct and you motor is running at it best while still running safe. Lots of stuff can be modified like your vtec crossover, ignition maps, a/f ratios, injector pulse, everything. If you can afford it I would suggest the chip and tune. Im pretty sure you will gain some power, but you will also have the piece of mind knowing your motor is running correctly.
Phearable.net's ECU's are good stuff.
I had one in my car (rare occurence where we THINK something has gone off inside the ecu) that I had to send back today, but they're checking it over to see if it's an internal fault on the ECU or if there's something wrong with my car.
But when I had it, you can most definitely tell the difference
Example: I used to end 3rd gear at ~100mph.....now I end it in the 105-110 range
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ekb18c5_BR »</TD></TR><TR><TD CLASS="quote">no
i have a stock p72(gsr)</TD></TR></TABLE>
if it runs good with that ecu don't get it chiped or tuned. if i were you i would just find the correct ecu for that motor and call it a day. can you justify mabe 15hp for $500, i couldn't. if your planning on turboing thats a different story, i would get it chiped with crome and have them put a base map on it to match your mod's like smileycvc said.
allnaturalb16
Sep 26, 2006 04:38 PM
