Cylinder Rust
Old Sep 13, 2007 | 11:09 AM
battlecrxT's Avatar
Default Cylinder Rust
Block left outside and 1 and 4 cylinder has a nice amount of rust on the cylinder walls. Whats the best way to remove the rust just enough to get the pistons out and the block to the machine shop? It was left out for a month,so you can draw your own picture.
Old Sep 13, 2007 | 12:06 PM
Romulan_7's Avatar
Default Re: Cylinder Rust (battlecrxT)
Never actually done this, so you may want to get a different opinion before you try it, but it would seem like you could just sand the rust off if you were going to get the block machined anyway.
Old Sep 13, 2007 | 01:43 PM
battlecrxT's Avatar
Old Sep 13, 2007 | 01:59 PM
Kevlar1's Avatar
Default Re: (battlecrxT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by battlecrxT &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
i honeslty don't that can be salvaged. maybe if you go .5 over
Old Sep 13, 2007 | 02:51 PM
battlecrxT's Avatar
When rust forms on metal like so what kind of reaction happens? I know something bad happens.
Old Sep 13, 2007 | 05:23 PM
standbackimapro's Avatar
It can Make Pitted holes, that can go all the way through the cylinder, which in that case no matter how much you bored it, it would still be there, but maybe its just a service rust..
To get the pistons out i would probably spray the **** out of it with a rust penetrant ( somthing good like pb blaster)
Then let it sit and try pounding them out with a dead blow or somthing... then maybe get one of the drill powered cylinder hones from the auto parts store,
Old Sep 14, 2007 | 08:42 AM
Golden Eagle's Avatar
i would just spray it with some wd40 and let it soak in then knock the pistons out after that i would sagest going 20 over
Old Sep 14, 2007 | 08:45 AM
battlecrxT's Avatar
Default Re: (Golden Eagle)
Thats exactly what I was thinking, what stock honda pistons would drop in there after .20 0ver?
Old Sep 14, 2007 | 09:01 AM
you can just order the pistons for your block in 20 over or if its a b sires block you can step up to itr or ctr pistons in 20 over
Old Sep 14, 2007 | 09:14 AM
MeanGreenMachine's Avatar
my block that i have isnt rusted that bad, but what i usually do to keep the walls from rusting is lube it up with some wd-40. my b series build has come to a halt and i am not able to finish it right now so i just let the block sit in my house in a trash bag. i lubed the cylinder walls with wd40 as well, but id take golden eagle's advice and do what he said
Old Sep 14, 2007 | 09:33 AM
battlecrxT's Avatar
That sounds like a deal. What do you guys think about the ebay pistons? Ive checked out one guy already ebay s/n:automotivepropr.com
Old Sep 14, 2007 | 10:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by battlecrxT &raquo;</TD></TR><TR><TD CLASS="quote"> That sounds like a deal. What do you guys think about the ebay pistons? Ive checked out one guy already ebay s/n:automotivepropr.com</TD></TR></TABLE>
is the block you have a single cam block? possibly a d16y or d16z block?
if it is a single cam block, are you wanting to put vitara pistons in it?
angry_LS
Jan 27, 2005 08:32 AM
pubestripe
Dec 17, 2004 10:48 PM
baphomet
Dec 8, 2003 02:00 PM
JohnnyEF
May 28, 2003 02:54 PM
Wicked Sol
May 11, 2002 04:36 PM
