ignition system question for 400HP
Old Sep 12, 2007 | 04:30 AM
94sol's Avatar
Default ignition system question for 400HP
I've done a few search's and I'm still a little confused about what I'm going to need to use. right now I have a del sol with a b16a3, pretty stock but I'm having a engine built with darton sleeves and forged internals.
My question: I know the stock igntion system is good till a certain amount of HP (not sure the exact number) but with the new setup I should be pushing around 350-400 HP and I'm worried the stock igntion will not be enough.
I've been reading about the MSD and it seems they are getting some bad reviews...what options do I have?
Old Sep 12, 2007 | 01:38 PM
King V's Avatar
Default Re: ignition system question for 400HP (94sol)
Drill out the center of the dizzy cap and put in a terminal to accept an external hi-po coil. Ive seen it done on a few cars.
Old Sep 12, 2007 | 04:19 PM
94sol's Avatar
Default Re: ignition system question for 400HP (200kCivicSI)
I've seen that before too, I've also seen you can buy caps already like that. I was hoping for a little more information on brands and more spacific setups. From what I've been reading MSD isn't getting the best reviews, but I would think the stock ignition wouldn't be enough
Old Sep 12, 2007 | 10:53 PM
locash's Avatar
OEM will be fine for your goals. Don't waste your time or money on anything else.
Old Sep 12, 2007 | 11:50 PM
doood's Avatar
been there done that
Default Re: ignition system question for 400HP (locash)
get all new oem wires, rotor, and cap. get the correct heat range plugs and gap them accordingly.
Old Sep 13, 2007 | 03:07 AM
94sol's Avatar
How much HP can the OEM system handle?
Old Sep 13, 2007 | 08:36 AM
standbackimapro's Avatar
You can try Mallory Ignitions, friend of mines using the Hyfire 6AL
http://www.malloryracing.com/P...ion=1
Old May 27, 2008 | 03:21 AM
gibsanez's Avatar
Default Re: (standbackimapro)
I've never heard any good things about the MSD ignition set ups for Honda/Acura.
I would rock the stock (refreshed) ignition.
Old May 27, 2008 | 06:43 PM
96 GSR-T's Avatar
Stock ignition here, you will be fine. The Analog stuff from MSD is junk but the Digital 6/7 are good units IMO.
hbhonda
Sep 4, 2005 10:35 AM
Aeka GSR
Oct 23, 2004 01:10 PM
92HB_HB
Apr 7, 2004 03:50 PM
calib17a
Mar 22, 2004 07:13 AM
kungfuSiR
May 18, 2002 04:08 PM
