Exactly what bolts do I need to take off to remove the alternator (98 Civic EX)
Old Sep 7, 2007 | 03:25 PM
CBL9's Avatar
Default Exactly what bolts do I need to take off to remove the alternator (98 Civic EX)
I have the one 14mm nut on the bottom off, trying to pry the bolt out of the bracket, I have the 12mm bolt out of the top, I disconnected the connector, and the ground. Do I need to remove the entire bracket from the car, or can I just remove the alternator? Not sure what to do next.
Old Sep 7, 2007 | 03:28 PM
SiREJ8's Avatar
remove lower bracket slide out alternator
Old Sep 7, 2007 | 03:48 PM
Danronian's Avatar
Slide makes it sound so easy..haha
Sometimes they need to be pried with a long screwdriver to push them toward the firewall enough to get them to come out.
There is also a small nut holding a ground wire on it, and a clip of wires on it too. Removing them now is usually best since it's still stuck and not moving around.
MR_Se7en
Mar 25, 2008 10:04 AM
--eclipse--
Jun 18, 2007 08:55 PM
Jeff
14
Oct 19, 2005 12:02 AM
Park
Dec 19, 2004 03:09 PM
Street Racer
Mar 15, 2002 11:43 AM
