Help! D-series valve adjustment (Dist. Rotor?)
Old Jun 15, 2002 | 04:55 PM
Todd00's Avatar
I said I don't want a title!
Default Help! D-series valve adjustment (Dist. Rotor?)
When adjusting the valves on a D15B7, upon starting you need to get the #1 cylinder at TDC (easy) and then the Distributor rotor pointing at the #1 plugwire. How the heck can you tell that? Am I missing something here, because I can't find anything on the dist. that points toward the #1 plug wire.
Help!
Old Jun 15, 2002 | 05:51 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Help! D-series valve adjustment (Todd00)
pull the cap off..........look for the white tip on the rotor.......when motot at TDC it will be pointing at #1 or #4 wire terminal on the cap.
Old Jun 15, 2002 | 06:26 PM
Avante's Avatar
I thought that the D16 motors had the marks on the camgear that you line up with the deck of the block to tell you that the motor is at TDC?
Old Jun 15, 2002 | 07:57 PM
Todd00's Avatar
Default Re: Help! D-series valve adjustment (Avante)
That's what I did. I took a guess on the dist. rotor thing and I assume I got it right.
If I didn't and I adjusted #1 when it was pointing at #4, what would happen?
Old Jun 15, 2002 | 07:59 PM
DragII's Avatar
25 Year Member
you'd have adjusted the valves on the intake stroke when they should be on exhaust, causeing overlap, and possible damage.
Old Jun 15, 2002 | 08:06 PM
Todd00's Avatar
Default Re: Help! D-series valve adjustment (SuperDragII!!!)
Well, it sounds pretty smooth and revs out nicely, so I assume all is good, right? Can't say that I notice any power difference though and one or two seemed to be out of spec by a lot before I did them.
Old Jun 15, 2002 | 08:18 PM
DragII's Avatar
25 Year Member
sounds good then.
BTW proper procedure was to find TDC on the mark on the crank pully, then remove the cap, and make sure the rotor is pointing @ #1
Old Jun 15, 2002 | 08:28 PM
Todd00's Avatar
Default Re: Help! D-series valve adjustment (DragII...Enfuego!!!)
I did that method, but the Helms manual and the Haynes manual were both very vague about the Distributor rotor being lined up. Neither one gave pics, hints, etc...they just said to do it.
Now I know. Thanks for the help guys.
bakin1988
May 14, 2009 08:08 AM
LukieLuc
Apr 2, 2007 06:13 PM
monalisa overdrive
Apr 13, 2004 05:46 PM
SearchBeforeUPost!
Sep 24, 2003 01:01 PM
crxaddikt
Oct 10, 2002 04:38 AM
