hid problem plz help
Old Sep 6, 2007 | 02:39 AM
TURBODC4TEG's Avatar
Default hid problem plz help
i just got a brand new hid kit. plugged everything in upgraded the fuses. had everything for about 3 days. when i turn them on they are fine but as soon as i drive down the road they flicker but remain on with no other issues. i searched as well! bad ballast, bad bulb? i have the balllast mounted slanted. could i lay them flat and see if that works. everything is plugged in tight i will double check again. oh i have no relay either
thanks
Old Sep 6, 2007 | 02:44 AM
Default Re: hid problem plz help (TURBODC4TEG)
still searching, any help would be appreciated
thanks
Old Sep 6, 2007 | 06:04 AM
anyone?
Old Sep 6, 2007 | 07:03 AM
imissmyhonda's Avatar
check the grounds i had the same problem what i didnt know what the ballast box needed to b on metal, they use the ballast as a ground. at least on the kit i have but mine is GHETTTTOOOO
Modified by imissmyhonda at 9:12 AM 9/6/2007
Old Sep 6, 2007 | 08:41 AM
Default Re: hid problem plz help (imissmyhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imissmyhonda &raquo;</TD></TR><TR><TD CLASS="quote">check the grounds i had the same problem what i didnt know what the ballast box needed to b on metal, they use the ballast as a ground. at least on the kit i have but mine is GHETTTTOOOO
Modified by imissmyhonda at 9:12 AM 9/6/2007</TD></TR></TABLE>
k thanks anyone else, i'm gonna try that.
Old Sep 6, 2007 | 09:33 AM
ITLNstallion818's Avatar
yeah definitely sounds like a grounding issue
Old Sep 7, 2007 | 04:59 AM
Default Re: hid problem plz help (ITLNstallion818)
well i checked my wires everything is right. also it only does it sometimes. so do i need to mount the ballast on metal for a ground for sure?
Old Sep 8, 2007 | 03:52 AM
up
Old Sep 8, 2007 | 10:50 AM
Shaun's Avatar
water ever got in the ballast?? i had this problem before and the ballast went bad on me
Old Sep 8, 2007 | 11:15 AM
Default Re: (Shaun)
up again
Old Sep 8, 2007 | 11:16 AM
BlackoutVTi's Avatar
Default Re: (TURBODC4TEG)
Heehee, now I get to refer you to the brand new lighting section!
https://honda-tech.com/zeroforum/107
There you go. This post will be good to help the section grow, so if you could have your topic relocated to there, that'd be great.
Old Sep 9, 2007 | 05:51 AM
Default Re: (BlackoutVTi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackoutVTi &raquo;</TD></TR><TR><TD CLASS="quote">Heehee, now I get to refer you to the brand new lighting section!
There you go. This post will be good to help the section grow, so if you could have your topic relocated to there, that'd be great. </TD></TR></TABLE>
thanks but it doesn't answer my question. does anyone know thanks
Old Sep 10, 2007 | 10:36 AM
jesus man wtf, anyone?
Old Sep 10, 2007 | 10:21 PM
now flickering off and on
Old Sep 10, 2007 | 10:53 PM
1llmatic's Avatar
New User
bad ballast. warranty that ****!
Old Sep 10, 2007 | 11:58 PM
JDM EM1 17's Avatar
bad ballast
Old Sep 11, 2007 | 06:50 PM
Default Re: hid problem plz help (JDM EM1 17)
anyway to make sure its the ballast? i had some wires loose fixed them. still does it. i'll start up car and wait a few mins then it looks like the driver side blinks. i have switch the bulbs on both sides to see if it was the bulbs and they lit up fine. plz help tried searching
Old Sep 11, 2007 | 07:01 PM
1llmatic's Avatar
New User
the question was answered.
Its the Ballasts...warranty it
I had the same thing happen to me when my ballast was going...
Old Sep 12, 2007 | 01:08 AM
Default Re: hid problem plz help (1llmatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1llmatic &raquo;</TD></TR><TR><TD CLASS="quote">the question was answered.
I had the same thing happen to me when my ballast was going...</TD></TR></TABLE>
well i keep calling the place and the guy says to this and that. giving me the run around. sure it can't be solved with a relay kit? 100% its the ballast?
Old Sep 12, 2007 | 02:20 AM
Thizzed Out's Avatar
no it wont be solved with a relay harness. BUT you should really get one after you get new ballasts. I've burned my stock light harness without one, good thing i catched it before it caught on fire!
Old Sep 12, 2007 | 02:25 AM
slowpokecivic's Avatar
Default Re: hid problem plz help (Thizzed Out)
you have two things that might be wrong and both have been answered in this thread...
a) you have a bad ballast
b) the grounds are weak and need direct contact to metal on the frame...
mine are flickering now but only because i have a bad ground...
Old Sep 12, 2007 | 11:56 AM
Default Re: hid problem plz help (slowpokecivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokecivic &raquo;</TD></TR><TR><TD CLASS="quote">you have two things that might be wrong and both have been answered in this thread...
mine are flickering now but only because i have a bad ground...</TD></TR></TABLE>
how would i wire the new ground to the metal? from the headlight wire or where it connects from the hid kit?
Old Sep 14, 2007 | 09:50 AM
up
Old Sep 15, 2007 | 12:01 AM
from where it connects to the hid kit...
Matt2458
Feb 23, 2011 05:03 PM
dc4teg95
Lighting
Feb 2, 2011 03:30 AM
vtek9
Lighting
Nov 14, 2007 12:54 PM
spoon-eg
Feb 19, 2005 08:10 AM
teamm_AP1
12
Dec 9, 2004 02:25 PM
