hid problem plz help
i just got a brand new hid kit. plugged everything in upgraded the fuses. had everything for about 3 days. when i turn them on they are fine but as soon as i drive down the road they flicker but remain on with no other issues. i searched as well! bad ballast, bad bulb? i have the balllast mounted slanted. could i lay them flat and see if that works. everything is plugged in tight i will double check again. oh i have no relay either
thanks
thanks
Re: hid problem plz help (TURBODC4TEG)
check the grounds i had the same problem what i didnt know what the ballast box needed to b on metal, they use the ballast as a ground. at least on the kit i have but mine is GHETTTTOOOO
Modified by imissmyhonda at 9:12 AM 9/6/2007
Re: hid problem plz help (imissmyhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imissmyhonda »</TD></TR><TR><TD CLASS="quote">check the grounds i had the same problem what i didnt know what the ballast box needed to b on metal, they use the ballast as a ground. at least on the kit i have but mine is GHETTTTOOOO
Modified by imissmyhonda at 9:12 AM 9/6/2007</TD></TR></TABLE>
k thanks anyone else, i'm gonna try that.
Re: hid problem plz help (ITLNstallion818)
well i checked my wires everything is right. also it only does it sometimes. so do i need to mount the ballast on metal for a ground for sure?
Re: (TURBODC4TEG)
Heehee, now I get to refer you to the brand new lighting section!
https://honda-tech.com/zeroforum/107
There you go. This post will be good to help the section grow, so if you could have your topic relocated to there, that'd be great.
Re: (BlackoutVTi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackoutVTi »</TD></TR><TR><TD CLASS="quote">Heehee, now I get to refer you to the brand new lighting section!
There you go. This post will be good to help the section grow, so if you could have your topic relocated to there, that'd be great. </TD></TR></TABLE>
thanks but it doesn't answer my question. does anyone know thanks
Re: hid problem plz help (JDM EM1 17)
anyway to make sure its the ballast? i had some wires loose fixed them. still does it. i'll start up car and wait a few mins then it looks like the driver side blinks. i have switch the bulbs on both sides to see if it was the bulbs and they lit up fine. plz help tried searching
Re: hid problem plz help (1llmatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1llmatic »</TD></TR><TR><TD CLASS="quote">the question was answered.
Its the Ballasts...warranty it
I had the same thing happen to me when my ballast was going...</TD></TR></TABLE>
well i keep calling the place and the guy says to this and that. giving me the run around. sure it can't be solved with a relay kit? 100% its the ballast?
no it wont be solved with a relay harness. BUT you should really get one after you get new ballasts. I've burned my stock light harness without one, good thing i catched it before it caught on fire!
Re: hid problem plz help (Thizzed Out)
you have two things that might be wrong and both have been answered in this thread...
a) you have a bad ballast
b) the grounds are weak and need direct contact to metal on the frame...
mine are flickering now but only because i have a bad ground...
Re: hid problem plz help (slowpokecivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokecivic »</TD></TR><TR><TD CLASS="quote">you have two things that might be wrong and both have been answered in this thread...
mine are flickering now but only because i have a bad ground...</TD></TR></TABLE>
how would i wire the new ground to the metal? from the headlight wire or where it connects from the hid kit?
