Y8 axle stuck.....
Old Sep 2, 2007 | 09:07 AM
The Dirty EJ1's Avatar
Default Y8 axle stuck.....
Well i'm swapping my tranny because its stuck in 2nd gear. Well i'm TRYING to remove the axles from the transmission and they WONT move an inch... Is it because its stuck in gear or am I just being a little bitch in removing them.....
Thanks for the help.
Old Sep 2, 2007 | 09:19 AM
pdiggitydogg's Avatar
are you using anything to pry it out @ the base??
Old Sep 2, 2007 | 09:22 AM
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">are you using anything to pry it out @ the base??</TD></TR></TABLE> Yeah, first I used a pry bar but I couldn't get the right leverage on it, so I to a HEAVY duty flathead screwdriver....
Old Sep 2, 2007 | 09:25 AM
97Ej6mike's Avatar
You need to get yourself the correct tools, or jack your car up some more so you have some more space to work with.
It also helps to have a 2nd hand helping, someone pulling outwards on the axle, as you pry it out. Axles dont go in our out easy, so you cant go easy on them, you gotta manhandle em'.
Old Sep 2, 2007 | 09:35 AM
Jakester9500's Avatar
Default Re: (97Ej6mike)
wrap a chain around and yank the mother out.
Old Sep 2, 2007 | 09:36 AM
97Ej6mike's Avatar
Default Re: (Jakester9500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jakester9500 &raquo;</TD></TR><TR><TD CLASS="quote">wrap a chain around and yank the mother out.</TD></TR></TABLE>
Great way to also dislocate the CV ball joints
Old Sep 2, 2007 | 09:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">
Great way to also dislocate the CV ball joints </TD></TR></TABLE>
Agreed.... Well turns out a pry bar and some muscle do a great job, the only reason why I asked was because last time I removed the axles they slid out like butter.
thanks though!
GarageAlchemist
Jul 20, 2006 06:38 PM
kefka
Jul 16, 2004 03:34 PM
egizzle8
Nov 17, 2003 01:42 PM
tecnic1
Jul 11, 2003 07:23 PM
Lei Siew Long
Aug 14, 2001 11:55 AM
