Y8 axle stuck.....
Y8 axle stuck.....
Well i'm swapping my tranny because its stuck in 2nd gear. Well i'm TRYING to remove the axles from the transmission and they WONT move an inch... Is it because its stuck in gear or am I just being a little bitch in removing them.....
Thanks for the help.
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">are you using anything to pry it out @ the base??</TD></TR></TABLE> Yeah, first I used a pry bar but I couldn't get the right leverage on it, so I to a HEAVY duty flathead screwdriver....
You need to get yourself the correct tools, or jack your car up some more so you have some more space to work with.
It also helps to have a 2nd hand helping, someone pulling outwards on the axle, as you pry it out. Axles dont go in our out easy, so you cant go easy on them, you gotta manhandle em'.
Re: (Jakester9500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jakester9500 »</TD></TR><TR><TD CLASS="quote">wrap a chain around and yank the mother out.</TD></TR></TABLE>
Great way to also dislocate the CV ball joints
Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">
Great way to also dislocate the CV ball joints </TD></TR></TABLE>
Agreed.... Well turns out a pry bar and some muscle do a great job, the only reason why I asked was because last time I removed the axles they slid out like butter.
thanks though!
thanks though!
