Best way to make 14b externally wastegated
Old Aug 24, 2007 | 01:01 PM
I LOVE TO SPOON's Avatar
Default Best way to make 14b externally wastegated
Ok so im building up by 14b turbo to put on my D series motor, and want to make it externally gated because of the stock boost that the 14b is set at. What would be the BEST way to go about doing this? Theres not a way to ajust the 14b wastegate, like different springs?
Old Aug 24, 2007 | 01:06 PM
bigbadboy's Avatar
have u tried a boost controller??
Old Aug 24, 2007 | 01:41 PM
I tought a boost controller can only increase boost it cant bring boost down below what the wastegate is already set at.
Old Aug 24, 2007 | 08:13 PM
bigbadboy's Avatar
ooo i didn't know u were tring to make it come down. wat is it set at stock??? u should be ok if its like 10-12
Old Aug 24, 2007 | 08:17 PM
Kyle R's Avatar
Default Re: (bigbadboy)
Remove the wastegate actuator/arm. Weld the flapper door shut. Use an external wastegate
Old Aug 24, 2007 | 08:18 PM
Kyle R's Avatar
Default Re: (trashcanrepairman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy &raquo;</TD></TR><TR><TD CLASS="quote"> wat is it set at stock??? </TD></TR></TABLE>
Stock is 11 psi.
Old Aug 24, 2007 | 08:24 PM
project dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trashcanrepairman &raquo;</TD></TR><TR><TD CLASS="quote">Stock is 11 psi. </TD></TR></TABLE>
nope. stock is 8 psi. the extra 3 psi is controlled thru the dsm ecu
Old Aug 25, 2007 | 06:43 AM
TTT's Avatar
TTT
Default Re: (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
nope. stock is 8 psi. the extra 3 psi is controlled thru the dsm ecu</TD></TR></TABLE>
I would get 9psi on me dsm when it had a line going straight from the boost reference to the actuator.
You can make a o2 housing that mounts that external wastegate off the internatl wastegate port.
Something like this:
Old Aug 25, 2007 | 07:42 AM
HiProfile's Avatar
Default Re: (TTT)
I could swear I just answered this on HMT or something...
Get a different actuator, as you can really make any OEM bulb-style work. There are a couple old cars that had 5-7psi WG's, and I'm sure there are a few that are just waiting to be sold/given away because the owner went with an external.
If you want to go lower, I can't see why. You can always modulate the throttle to go a bit below max boost, as well as almost any Honda block can take 8psi from a 14b in stock form. Otherwise if you want to go higher, a $10 manual boost controller will work wonders...
Old Aug 25, 2007 | 10:07 PM
WOW!! Thanks guys on the info this gives me many directions that I can go with this, thats just another thing of my mind for my build, thanks!
seeeya04
Dec 3, 2005 04:34 AM
blackcivic44
Feb 1, 2005 07:45 PM
hatchracer02
Jan 10, 2005 05:13 AM
T-RO
Jun 28, 2004 04:16 PM
turbo Si
Mar 22, 2003 12:29 PM
