NEW TURBO SETUP ?'S
Old Aug 24, 2007 | 02:12 AM
mikex1021's Avatar
Default NEW TURBO SETUP ?'S
new turbo setup!!
alright this is my new setup, ive never built a turbo car before and i wanted to know if these parts are str8t.
b18c1 block with golden eagle sleeves 81.5mm
stock crank
eagle h beam rods
wiseco 9-1 pistons
b18c1 head
comp cam springs and tit retainers
bc3 camshafts
ss valves
bronze valve guides
skunk2 cam gears
aem afr
skunk2 im
edlebrock 65mm tb
pfabrications log manifold
pfabs 2.5in downpipe
turbonetics t3/t4 .63 stage 2 superh trim ceramic ball bearing
greddy rs bov
tial 38mm wastegate
walbro 255 fuel pump
rc750 injectors
tune on ectune by phearable
my main question is what ignition system do i need to run if ne for 350hp-450hp
all comments welcome, and opinions appreciated
Old Aug 24, 2007 | 03:42 AM
evokidvii's Avatar
Default Re: NEW TURBO SETUP ?'S (mikex1021)
the stock honda ingnition will be fine for the power levels you are looking at.. also i would upgrade from the 2.5 inch dp, to a 3 inch dp, with 3 inch all the way back.. good luck with it. and post up some numbers after you get tuned
Old Aug 24, 2007 | 06:13 AM
V3locity's Avatar
Default Re: NEW TURBO SETUP ?'S (evokidvii)
I'm interested in this as well. I recently bought a custom kit from a friend. I'll be building a gsr block for boost for it. Your setup looks more complete than mine currently.
At the moment my plan is to use
stock sleeves, maybe a blockguard...I'm unsure if I'll need it.
Eagle Rods
Wiseco Pistons 9:1-9.7:1 not really sure shich ones to buy yet
stock GSR head and IM
I do have BC4's but I'm thinking about selling them and just buying an intake cam.
Here's what I have in the kit
Garrett T3/T4e 54 trim .63
Inline Pro SS Manifold
3" DP w turndown
AEM Fuel Rail
AEM FPR
BBK 255
RC 750cc
Hondata s200b
Greddy Profec B
Tial 38mm
Apexi BOV
24" x 12" x 3" IC w piping
I'd like to shoot for 350-425 on high boost, what else do I need to reach that?
Old Aug 24, 2007 | 06:45 AM
93dagsr's Avatar
what is a block guard and what is the purpose?? also im planning on either boosting my ls or gsr? if i boos the gsr what comp/ratio are you using on the pistons?? are they stock pistons?? what octane are you running?? thanks!
Old Aug 24, 2007 | 10:48 AM
V3locity's Avatar
Default Re: (93dagsr)
Sorry for the thread hijack. I'd just like to see more input on building GSR's for boost. I've been in the all motor camp for some time now.
Old Aug 24, 2007 | 10:57 AM
ndogg's Avatar
Default Re: NEW TURBO SETUP ?'S (drumnbassej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumnbassej1 &raquo;</TD></TR><TR><TD CLASS="quote">I'm interested in this as well. I recently bought a custom kit from a friend. I'll be building a gsr block for boost for it. Your setup looks more complete than mine currently.
Eagle Rods
3" DP w turndown
AEM Fuel Rail
AEM FPR
BBK 255
RC 750cc
Hondata s200b
Greddy Profec B
Tial 38mm
Apexi BOV
your list has all the major things. there is ALOT of debate about block guards, I would NOT run one under any circumstance. You may want to get upgrades springs and retainers to carry the revs out a little past stock (not too far on stock sleeves though). and i'm not sure if that turbo can push 425hp.
edit: add cam gears.
Old Aug 24, 2007 | 12:33 PM
V3locity's Avatar
Default Re: NEW TURBO SETUP ?'S (ndogg)
Thanks for the feedback, I've heard both sides of the blockguard debate years ago. I'd rather not use it but I didn't know what the stock sleeves could hold.
I definitely plan on doing valvesprings when I do cams. Cam gears scare me, I've seen a lot of them slip. I'm honestly not stuck on 425, I just really want to break the 400whp mark.
Old Aug 25, 2007 | 06:15 PM
mikex1021's Avatar
also what is the differance between a oil catch can and a breather kit? or are they the same thing
Old Aug 25, 2007 | 10:09 PM
almostboostedgsr's Avatar
Default Re: (mikex1021)
Yeah your turbo is going to be dieing lol. My 57trim is only rated at 450whp and you have a 54trim. So yea upgrade to a bigger turbo. Get a 3inch downpipe and 3inch all the way back. Get larger injectors to be on the safe side. Valve springs and retainers wouldnt hurt. Then after that you should be good to rock.
js9771947
Mar 2, 2012 05:52 AM
js9771947
Feb 28, 2012 07:23 PM
.adam.
Mar 28, 2006 12:16 PM
AllMotorGSR94
Jan 26, 2006 07:53 PM
ExplicitSpeed
Mar 8, 2004 10:59 PM
