FS - Sleeved Gsr block
Old Aug 24, 2007 | 12:30 PM
wespirl's Avatar
Default FS - Sleeved Gsr block
Freshly sleeved Gsr block (0 miles)
- 81mm bore
- micropolished crank
- main caps
- girdle
- headstuds
$1,200 shipped
Old Aug 24, 2007 | 12:41 PM
SD_Lurker's Avatar
HT White Ops
Default Re: FS - Sleeved Gsr block (wespirl)
Dude those sure look like stock sleeves.
Old Aug 24, 2007 | 02:24 PM
95 integra's Avatar
Default Re: FS - Sleeved Gsr block (SD_Lurker)
If its sleeved, then its with stock replacement sleeves and not thicker aftermarket sleeves...not to mention you have a chip in the outside of that 3 cylinder sleeve.
Old Aug 24, 2007 | 02:39 PM
SuperiorSC's Avatar
Default Re: FS - Sleeved Gsr block (95 integra)
if you LOOK you can see that it is sleeved the stock sleeves have been bored out and replace with AFTERMARKET iron sleeves.... maybe im just seeing the pics ??
Old Aug 24, 2007 | 03:32 PM
95 integra's Avatar
Default Re: FS - Sleeved Gsr block (SuperiorSC)
Stock sleeves are "roughly" half aluminum and half steel....which is exactly what those look like. Aftermarket sleeves use the half and half design about half way up and then step to a full steel sleeve at the top.
dalejrfan88
Mar 6, 2012 05:46 PM
92frostwhtdb2
Dec 15, 2011 07:57 AM
DCtooD
Jul 28, 2010 07:43 PM
mannyman2
Jan 29, 2008 09:08 PM
laziebun
Oct 22, 2007 03:23 PM
