help plz, B16b preparing, tuning and adding turbo
Old Aug 22, 2007 | 11:51 AM
evz's Avatar
evz
Default help plz, B16b preparing, tuning and adding turbo
Hi all, am a noob here and am not on top wen it comes to under the hood.
Ive got a B16b in what was a 1.4 civic illusion.
Its lowered 70mil, on 17's, lambo doors, carbon bonnet, door cards, 90% full body kit change, buckets and harnesses, Im waiting for a 8 point cage and help on the turbo side.
Im after help on a stage 2 / 3 turbo setup on the b16b.
I know that its possible to have a b16b with a stage 3 setup with manual boost but im no petrol head so i have no idea what i need.
So far its;
8 pot front and back disc conversion
Greddy stage 3 turbo setup
540 bhp driveshafts
540 bhp clutch setup
uprated oil pump
valve train
high pressure fuel pump
550cc injectors
Stage 3;
cams
forged pistons
eagle rods
valves,valve guides and seals
cam seals
any help from you guys is greatly apprciated.
Old Aug 22, 2007 | 11:56 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: help plz, B16b preparing, tuning and adding turbo (evz)
I hope those are low compression pistons. 10.8:1 is kinda high for boost.
And what is a "stage 3"
Many companies definitions of stage 3 differ. What's the size of the turbo?
I hope you don't plan on daily driving with a roll cage. Bad Idea.
Old Aug 22, 2007 | 12:01 PM
EJ1chevelle's Avatar
Default Re: help plz, B16b preparing, tuning and adding turbo (ek forever guy)
^^^ what he said... dont boost that thing over 8 to 10psi or it will pop. with a stage 3 turbo kit you will probably need 8.5:1 to 9:1 compression and new rods made for boost... read up before you do this and get yourself in trouble. how many pounds you plan on running and what size turbo??
Old Aug 22, 2007 | 12:07 PM
evz's Avatar
evz
Default Re: help plz, B16b preparing, tuning and adding turbo (93egB16A)
The cars going to be on the road maybe twice a week but is mainly going to be used for track.
the one ive been looking at is the rev hard T04E Hybrid Turbo(eff. to 450hp)
7psi that is.
thanks
sorry forgot to add, the turbo adds in range of 120 hp 285 ft/lbs
Old Aug 22, 2007 | 12:08 PM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egB16A &raquo;</TD></TR><TR><TD CLASS="quote">^^^ what he said... dont boost that thing over 8 to 10psi or it will pop. with a stage 3 turbo kit you will probably need 8.5:1 to 9:1 compression and new rods made for boost... read up before you do this and get yourself in trouble. how many pounds you plan on running and what size turbo??</TD></TR></TABLE>
no
Old Aug 22, 2007 | 12:09 PM
ok there is no way you will make 450HP on 7 psi. my buddy has a hatch w/ a D16Z6 fully built on 28 psi making just over 460HP
Old Aug 22, 2007 | 12:15 PM
evz's Avatar
evz
Im looking for suggestions as of where to go with the project, what upgrades etc . Im not saying im going to be hitting whatever hp or whatever ft/lbs, just need help building the engine up into a beast
peace
Old Aug 22, 2007 | 12:19 PM
if you want to build it into a "beast" and wanna aim for 450HP then be prepared to spend some money. lower the compression and build a bottom end strong enough for 40psi so it is reliable. then you will need to get new cams and all that stuff to accomidate the forced air. do some research on all this and figure out how big of a turbo you want to run. quick spool or late spool with big kick.
Old Aug 22, 2007 | 12:21 PM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egB16A &raquo;</TD></TR><TR><TD CLASS="quote">ok there is no way you will make 450HP on 7 psi. my buddy has a hatch w/ a D16Z6 fully built on 28 psi making just over 460HP </TD></TR></TABLE>
only if you have a stupid gigantic turbo
Old Aug 22, 2007 | 12:27 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egB16A &raquo;</TD></TR><TR><TD CLASS="quote">if you want to build it into a "beast" and wanna aim for 450HP then be prepared to spend some money. lower the compression and build a bottom end strong enough for 40psi so it is reliable. then you will need to get new cams and all that stuff to accomidate the forced air. do some research on all this and figure out how big of a turbo you want to run. quick spool or late spool with big kick. </TD></TR></TABLE>
build the bottom end for 40psi so it can be reliable? isn't that kind of exaggertaing it a bit.
Old Aug 22, 2007 | 12:33 PM
Default Re: help plz, B16b preparing, tuning and adding turbo (philosofy1)
^^^ yes exageration alot but just so he gets what my point is.... he is a lil bit confused on exactly how a turbo and psi work with compression and a bottom end.
Old Aug 22, 2007 | 12:38 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egB16A &raquo;</TD></TR><TR><TD CLASS="quote">^^^ yes exageration alot but just so he gets what my point is.... he is a lil bit confused on exactly how a turbo and psi work with compression and a bottom end.</TD></TR></TABLE>
if he seems confused, then you should be providing proper info and guidance. not posting magical psi#'s and saying it's reliable.
evz's Avatar
evz
the pistons i have in mind are for b16b capable of upto 35psi, which i wudnt be going anywhere near, and theyre also capable of 900hp,
therl be no downsides going higher power ratings than you need with cams and pistons etc will there apart from the account balance?
but as you say i will have to research into compression ratios end everything else to try and work out how its to all come together.
edit - I cant reply anymore (says no mor than 5 posts per day) so this my last post for today the pistons are je pistons from CNC with 8.0, 9.0, 9.8, 10.7, 11.5 and 12.2 comprssion ratios available
Modified by evz at 2:29 PM 8/22/2007
Old Aug 22, 2007 | 12:39 PM
i did tell him stuff about compression with that post and what to do for lowering it and building....
Old Aug 22, 2007 | 12:41 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evz &raquo;</TD></TR><TR><TD CLASS="quote">
it's nice that you have an idea on what you want, but it's nothing if you don't get the right ecu and tune it.
tuning is the key to reach the goal you have in mind.
Old Aug 22, 2007 | 12:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evz &raquo;</TD></TR><TR><TD CLASS="quote">the pistons i have in mind are for b16b capable of upto 35psi,</TD></TR></TABLE>
what kind of pistons are those??? 35psi is crazy. what compression ratio are they?? i have a doubt that they are for 35psi...i was exagerating when i said 40 psi of boost. sorry if you misunderstood what i said.
Old Aug 22, 2007 | 07:51 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egB16A &raquo;</TD></TR><TR><TD CLASS="quote">what kind of pistons are those??? 35psi is crazy. what compression ratio are they?? i have a doubt that they are for 35psi...i was exagerating when i said 40 psi of boost. sorry if you misunderstood what i said. </TD></TR></TABLE>
stop saying psi! pistons dont care if you're throwing 5psi or 100psi at them. they can go to **** at either.
Old Aug 22, 2007 | 08:03 PM
Ek Forever y0!
Default Re: help plz, B16b preparing, tuning and adding turbo (doood)
amen, pistons don't break. rods, crank bearings, and rod bolts break. LOL
Old Aug 22, 2007 | 08:30 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote"> pistons don't break. </TD></TR></TABLE>
cast pistons break. forged pistons melt.
Old Aug 22, 2007 | 08:39 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">cast pistons break. forged pistons melt. </TD></TR></TABLE>
I know, but how often does that happen in stock engines?
Old Aug 22, 2007 | 08:40 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">I know, but how often does that happen in stock engines?</TD></TR></TABLE>
ricers are a tricky bunch
Old Aug 22, 2007 | 08:41 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">ricers are a tricky bunch</TD></TR></TABLE>
Especially the vtec cross-over changing, rev limit removing, hydro-locking kind.
Old Aug 22, 2007 | 08:52 PM
95ProjectEJ1's Avatar
With all that kid has listed Im imagining some $30k riced out civic...
IFP's and a build thread
Gaspari
Jul 1, 2010 01:12 AM
99Sir99
Aug 4, 2009 08:17 PM
wanabeTOSA
Sep 23, 2004 06:03 PM
AllMotorITR
Jan 13, 2002 08:07 AM
Trajic
Aug 20, 2001 06:54 AM
