ls vtec 15 psi "46 trim'?
Old Aug 21, 2007 | 09:49 PM
the.hamburglar's Avatar
Default ls vtec 15 psi "46 trim'?
has anyone had experience with a 46 trim compressor wheel? iv got a fully built ls vtec that im currently boosting 10psi on with a 60 trim to4e and its really laggy. i was thinking about the 50 trim but at 15 psi this 46 trim i found looks to be really good.
my setup will be a daily driver and the track a few times a year. thanks
http://www.rbracing-rsr.com/tu...6.gif
Old Aug 22, 2007 | 04:19 AM
blackeg's Avatar
Default Re: ls vtec 15 psi "46 trim'? (the.hamburglar)
a 60 trim should not be really laggy on an lsvtec.
if you want a turbo that has full spool at like 3k it will **** out up top.
Old Aug 22, 2007 | 04:22 PM
Default Re: ls vtec 15 psi "46 trim'? (blackeg)
doing all the calcs my motor will flow 40lbs/min at 15psi (or 2.02 pressure ratio) if you look at compressor map that turbo looks great. im just asking if anyone has ever used it before?
Old Aug 22, 2007 | 07:01 PM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">doing all the calcs my motor will flow 40lbs/min at 15psi (or 2.02 pressure ratio) if you look at compressor map that turbo looks great. im just asking if anyone has ever used it before?</TD></TR></TABLE>
Yes, used them before. they were very good for D-series and some LSs, but not for an LS/VTEC. the VTEC head is VERY efficient, even moreso than the "compressor map" wants to let on. Remember, Compressor maps are only the START of understanding which turbo "fits"
Old Aug 22, 2007 | 07:12 PM
poop II's Avatar
Default Re: ls vtec 15 psi "46 trim'? (TheShodan)
93
Agreed. I'd look into your hotside, exhaust setup, timing, and afr for the source of lagginess. I have the 40 trim on an aircooled vw and like it. However, while the smaller e wheels are great for stockish d-series and such, your current wheel is fine for the application and there is likely another cause for the lagginess.
93 93/93
Old Aug 23, 2007 | 04:18 PM
DrVtec99's Avatar
I run a t3/t4oe precission 50 trim
Compressor Wheel Dia.: 54mm
Compressor Wheel Inducer: 2.123"
Compressor Wheel Exducer: 3.000"
Compressor Wheel Trim: 50
Turbine A/R Ratio: .63
Turbine Wheel Style: T31
Turbine Wheel Inducer: 2.559"
Turbine Wheel Exducer: 2.228"
I did alot of looking around before i decided to buy. I didn't want to jump on the 60trim band wagon. The 50 trim is more effecent that the 57 and has a better power band than the 60. I am currently running mine 14 psi of the gate. Its very responsive and it hasn't let me down. The only other turbo i would run on my setup is a gt3076r.
Old Aug 23, 2007 | 04:34 PM
ferio82's Avatar
Default Re: ls vtec 15 psi "46 trim'? (DrVtec99)
gt3076r .82 hotside FTW, i love my unit. nothing beats the sound of a ball bearing sppoling oh and no spooling problems on my b20 vtec
Old Aug 23, 2007 | 07:13 PM
Default Re: ls vtec 15 psi "46 trim'? (ferio82)
do you have almost instant throttle response with the gt30? thats what ir ealy want but cant afford it right now
Old Aug 23, 2007 | 07:16 PM
ferio82's Avatar
not instant, but when she kicks she kicks
Old Aug 23, 2007 | 07:30 PM
DCxMagus's Avatar
if you want a better spool time your going to sacrific top end and vise verse thats just the way it is.
for a daily driver thats going to see the track less then 10 times a year, you probably want a bit smaller turbo so that you get that nice instant kick on the street where you need it.
sadly to say for that your not going to be the fastest kid in town but honestly who cares, a street car should be fun to drive, whats the point of having 400whp past 6K if you only see past 6K once a day or less?
but before you go swapping out your turbo check a few things first
are you sure theres not a boost leak anywhere?
what type of boost control are you using if your running of the gate your spool up is going to be slower remember, a good EBC can fix that.
have you looked into a similar sized BB like mention above?
theres lot of things that can attribute to a slow/laggy response time your turbo isn't way oversized for your application or anything so I would look into those before getting a new turbo.
Old Aug 23, 2007 | 08:04 PM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio82 &raquo;</TD></TR><TR><TD CLASS="quote">gt3076r .82 hotside FTW, i love my unit. nothing beats the sound of a ball bearing sppoling oh and no spooling problems on my b20 vtec </TD></TR></TABLE>
wish i had that kind of money. instead i cheaped out wiht a 60-1
Old Aug 23, 2007 | 08:23 PM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">
wish i had that kind of money. instead i cheaped out wiht a 60-1</TD></TR></TABLE>[QUOTE=blackeg]
You didn't "cheapen" out. The 60-1 can still be a great combination depending upon the use. You're ok.
the.hamburglar
Aug 17, 2007 04:21 AM
deca
Feb 11, 2006 06:05 PM
boostdummy
Jan 27, 2006 01:24 AM
2LiterTurboSeR
Apr 4, 2005 07:14 AM
my ride
Apr 21, 2004 06:12 PM
