Wierd Battery issues!?!?!?!
Old Aug 17, 2007 | 07:56 AM
DarkBB4's Avatar
Default Wierd Battery issues!?!?!?!
hey, well i replaced my oddyssey 680 w/ a Energizer battery in the trunk. It has 560 CCA and should have no problem starting the car. Although I keep getting stuck in gas stations and anywhere I stop the car...
car runs at 14.0 VOLTS (apexi RSM voltmeter)
and battery reads 11.8 volts when the car is in the ON position but when i try to crank it, it drops down really low and doesn't even crank...
Now i think that the cells are garbage, and the battery is junk... although its not even 4 months old
Could Main Relay be an issue?
SOMETHING IS DRAINING MY BATTERY!?!
this is how i have it set up
Modified by DarkBB4 at 12:59 PM 8/23/2007
Old Aug 23, 2007 | 11:59 AM
DarkBB4's Avatar
Default Re: Wierd Battery issues!?!?!?! (DarkBB4)
TTT
Old Aug 23, 2007 | 12:12 PM
mgags7's Avatar
evan how you have that going into the fusebox is no good
go to circuit city or something and get a power distribution block. then split those two lines and have the one run up to the fusebox and the one to the starter seperate.
where did you get that breaker for the battery
Old Aug 23, 2007 | 12:22 PM
DarkBB4's Avatar
Default Re: (mgags7)
ok cool, could that be the problem?
Old Aug 23, 2007 | 12:42 PM
h22 civic's Avatar
Default Re: (DarkBB4)
where do you have it grounded to?
Old Aug 23, 2007 | 01:51 PM
DarkBB4's Avatar
Default Re: (h22 civic)
the battery? its grounded Right under the box... to a BIG *** bolt.. I'm going to check it out asap
do you think the thickness of the ground wire is ok? its an OEM sized ground wire
Old Aug 23, 2007 | 03:13 PM
mgags7's Avatar
just make sure there is no paint btw body and ground wire.
Old Aug 23, 2007 | 04:07 PM
h22 civic's Avatar
that is a common problem when relocating the battery to the rear best way is to run a ground wire back to the front and groung to motor
Old Aug 23, 2007 | 05:36 PM
mgags7's Avatar
I could be wrong, but nearly everyone who puts the battery in the trunk grounds it back there too.
Mine is like that and I don't think its causing any problems, though I could be wrong.
Old Aug 23, 2007 | 05:42 PM
lude98SH's Avatar
11.8 volts is low you should be at 12.45 at the lowest which is 75% charged. 14.0 volts running is about right. If you work at a shop you could do a load test on the battery using a VAT which would tell you if the battery is bad or not for sure.
Old Aug 23, 2007 | 05:53 PM
prelude_h22vtec's Avatar
^ you beat me to it. i was going to give the exact same answer.
check for parasitic draw too
charge your battery up to 12.6v
Modified by prelude_h22vtec at 7:04 PM 8/23/2007
Old Aug 23, 2007 | 07:00 PM
mgags7's Avatar
Default Re: (lude98SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">11.8 volts is low you should be at 12.45 at the lowest which is 75% charged. 14.0 volts running is about right. If you work at a shop you could do a load test on the battery using a VAT which would tell you if the battery is bad or not for sure. </TD></TR></TABLE>
12v is a full charge on a battery, and 11.8v is completely normal in my experience.
the 14v is from the alternator running.
Old Aug 23, 2007 | 07:04 PM
no buddy, 12v is not a full charge, full charge is 12.6v. 12.0v is like 25% charge. i know it sounds crazy but its true.
Old Aug 23, 2007 | 07:29 PM
mgags7's Avatar
actually, buddy, its 12v
you can buy some other battery that charges to 12.6v if you like, the battery manufacturers are pretty lax with their standards. but honda spec is 12v. everything on the car is 12v, with the exception of the interior lights which are regulated to 5v
no1knows908's Avatar
Default Re: (prelude_h22vtec)
Yea I work at AutoZone and charge and test batteries every day. Usually when the battery comes off the charger with 100% charge the tester reads approximately 12.5
Old Aug 23, 2007 | 07:43 PM
ok i want you (mgags) to go outside right now with a DMM and check the voltage on your battery. if its only 12.0, i will give you 100 dollars. i know what i'm talking about. honda batteries are no different than the others
Old Aug 23, 2007 | 07:53 PM
mgags7's Avatar
you would be 100 bucks in the hole dude
my battery has been 11.8v for the past two years since I bought it.
I'm not trying to start some huge argument here, the difference between 12v and 12.6v is minimal.
Old Aug 23, 2007 | 07:58 PM
please read up. i'm not gonna argue anymore.
here i found something on wikipedia
http://en.wikipedia.org/wiki/Car_battery
12.65 V 100%
12.45 V 75%
12.24 V 50%
12.06 V 25%
11.89 V 0%
Old Aug 23, 2007 | 08:17 PM
mgags7's Avatar
ok I don't measure open circuit voltage of my battery ever, it puts 11.8v to the rest of the car and that is what matters.
good article for the uneducated people around here.
Old Aug 24, 2007 | 06:40 AM
DarkBB4's Avatar
ok, so how do i fix this !!!
ill get a distribution block asap! but should i buy a new battery?
Old Aug 24, 2007 | 06:41 AM
mgags7's Avatar
I say no, they say yes.
My car works (shrug)
Old Aug 24, 2007 | 07:48 PM
LukieLuc's Avatar
I say get the battery charged and tested at AutoZone for free than see if you need a new battery
Johnoolo
Sep 16, 2013 05:15 AM
schueytenten
Oct 23, 2010 03:45 AM
mysterysktr7
Jul 10, 2009 09:09 PM
crxaddikt
Apr 5, 2009 01:45 PM
darwinizm
Jan 8, 2005 08:34 PM
