How much is power steering worth?
I just pulled the power steering stuff off my EX sedan, lines, pump, reservoir, cooler, and the rack, etc. Basically everything but the mount bracket. How much do these units go for used? I want to sell mine.
wrong area to post this. and personally PS is basically a waste espicially for little cars like ours. If it is swappable you should be able to make some, not much.
LOL but I do love peanut butter
Well I know there isn't much tech but I couldn't figure out what other forum to put this in. If you want some tech about the ps I can say this. You have to drop the shift linkage and lower the cat back basically to pull out the rack because its a lot bigger than the non-ps rack. Also when you go to put in the non-ps rack on the old cross member the one bracket that holds it up doesn't line up to the same hole so you have to modify it a little bit to work correctly. Otherwise its a pretty easy swap.
georgiajdm
Oct 20, 2002 07:47 PM
