will a vtec motor run on a nonvtec ecu?
Old Aug 13, 2007 | 07:32 PM
be18see1's Avatar
Default will a vtec motor run on a nonvtec ecu?
im going to try to start my swap for the first time 2mo, but i havent run the wires for vtec and the knock sensor yet. it will run and drive on the non vtec ecu correct? just not very well? its a b18c1 into a 93 da.
Old Aug 13, 2007 | 08:04 PM
SYTFU Tommy.'s Avatar
Default Re: will a vtec motor run on a nonvtec ecu? (be18see1)
it will work, but w/o vtec and redline at 7k. it will run the car, but might be running a little crappy though.
Old Aug 13, 2007 | 08:22 PM
grundle's Avatar
Default Re: will a vtec motor run on a nonvtec ecu? (SYTFU Tommy.)
i ran my built b18c1 on my old ls ecu for the first 3k miles. It ran fine just redlined at 7000, and no vtec. i would just drive it normal and if you feel you have to get on it check your plugs to make sure your not going lean.
Old Aug 13, 2007 | 09:59 PM
GSR in progress 96's Avatar
* B A N N E D *
It will run but you should get the right ECU as soon as you can
Old Aug 14, 2007 | 05:39 AM
be18see1's Avatar
Default Re: will a vtec motor run on a nonvtec ecu? (GSR-(soon to be)T)
i have the obd1 p72, but it wont run w/o the knock sensor wired up right? i just want to start it up.
Old Aug 14, 2007 | 11:23 AM
projectTeG's Avatar
it will start without the knock sensor hooked up you just wont have vtec. oh and yes you can run it on a Non-vtec ecu.
Old Aug 14, 2007 | 11:46 AM
dizzzane's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">it will start without the knock sensor hooked up you just wont have vtec. oh and yes you can run it on a Non-vtec ecu.</TD></TR></TABLE>
This is correct.
Old Aug 14, 2007 | 01:33 PM
killacam661's Avatar
Default Re: (MilanoRed_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MilanoRed_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
This is correct. </TD></TR></TABLE>
well i have a 95 gsr in a 94 lks and i never had my knock sensor wired up(it was broke off) and i just wired up vtec and put in a chipped p72 and vtec works perfect. how u like dem apples
Old Aug 14, 2007 | 01:46 PM
doood's Avatar
been there done that
Default Re: (killacam661)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killacam661 &raquo;</TD></TR><TR><TD CLASS="quote">
well i have a 95 gsr in a 94 lks and i never had my knock sensor wired up(it was broke off) and i just wired up vtec and put in a chipped p72 and vtec works perfect. how u like dem apples </TD></TR></TABLE>
you can disable the knock sensor with a chipped ecu
Old Aug 14, 2007 | 01:49 PM
projectTeG's Avatar
well i have a 95 gsr in a 94 lks and i never had my knock sensor wired up(it was broke off) and i just wired up vtec and put in a chipped p72 and vtec works perfect. how u like dem apples </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">
you can disable the knock sensor with a chipped ecu</TD></TR></TABLE>
+1
Old Aug 14, 2007 | 01:50 PM
Default Re: (doood)
true that is. i wonder if my ecu has that disabled then. cuz i have no redline and vtec is at 4400.
GET A GSR ECU AND SMASH OUT
Old Aug 15, 2007 | 09:28 AM
dizzzane's Avatar
Your ECU does have the knock sensor disabled, like I said before, it won't run without it.
Old Aug 15, 2007 | 11:42 AM
91redteg's Avatar
a gsr with no vtec. thats like a chick with no *****.
Old Aug 15, 2007 | 11:46 AM
dizzzane's Avatar
Default Re: will a vtec motor run on a nonvtec ecu? (91redteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91redteg &raquo;</TD></TR><TR><TD CLASS="quote">a gsr with no vtec. thats like a chick with no *****. </TD></TR></TABLE>
Haha thats pretty good.
Old Aug 15, 2007 | 09:43 PM
GSR-TRBO-DA's Avatar
ls ecu will run it. you don't need knock sensor if you are chipped if not then you do. i thought on gsr motors the primary vtec kicks in at like 4500 and the secondary butterfly opens at like 5600 or something . i'm not sure about the vtec but the knock sensor i know for sure.
Old Aug 17, 2007 | 08:14 PM
be18see1's Avatar
Default Re: will a vtec motor run on a nonvtec ecu? (GSR-TRBO-DA)
well heres the deal. i wired vtec up, but no knock sensor bc i couldnt find where the third wire runs for the knock sensor. i think its for 5 volts, but i dont know where to tap into. it runs with no knock sensor and i can take it up to 8k fine. i dont have butterflies, bc i swapped on a blox im. also, i cant really hear vtec at all, but i think thats normal with the c1.
philivtec
Mar 31, 2008 11:26 PM
crispchris
Jun 28, 2007 09:00 AM
1SickEG
Jan 17, 2007 03:05 PM
hotteg04
Dec 22, 2004 01:02 PM
0554
Jun 10, 2003 05:41 PM
