B16A oil cap pressure?
Old Jun 12, 2002 | 01:42 PM
keebler65's Avatar
Default B16A oil cap pressure?
i installed my B16A and i notice that when its running, if i remove the oil filler cap and put my hand above the hole, there is a definate pressure because i can feel quite a bit of air coming out. is this normal? my friend said he thought it meant blown piston rings, but he wasnt sure. i guess i dont remember this on my old motor but then again i never checked. i just want to know that my motor is ok.
thankyou!
Old Jun 12, 2002 | 01:58 PM
Kamin's Avatar
Default Re: B16A oil cap pressure? (keebler65)
do a compression test
Old Jun 12, 2002 | 10:45 PM
keebler65's Avatar
ok i will as soon as i get access to a tester. hope there's nothing wrong...
Old Jun 12, 2002 | 10:55 PM
tinkerbell's Avatar
dude!
your engine is probably fine!!
it is normal for an internal combustion engine to have crankcase pressures, it is from the pistons moving up and down inside the block and should be a NET pressure of ZERO
ie some coming in and some going out,
try placing your palm over the hole to see if it gets blown off?
if not, it seems to be normal.
anyone back me up on this?
t..
[Modified by tinkerbell, 5:55 PM 6/13/2002]
Old Jun 13, 2002 | 04:59 AM
Mike K's Avatar
Default Re: B16A oil cap pressure? (tinkerbell)
your engine is fine.
Old Jun 13, 2002 | 06:44 AM
sackdz's Avatar
Default Re: B16A oil cap pressure? (Mike K)
So is your mom.
Old Jun 13, 2002 | 08:49 AM
keebler65's Avatar
Default Re: B16A oil cap pressure? (sackdz)
yeah i'm not really worried about my mom but thanks guys thats extremely reassuring to know.
thankyou!
Old Jun 13, 2002 | 09:57 AM
Crazydave's Avatar
...so if I put my hand over your moms hole...
and do a compression test.....
This is normal..
think about it... crankcase ventilation.... breathers.. they are there for a reason
Old Jun 13, 2002 | 02:51 PM
fsarfino's Avatar
Default Re: B16A oil cap pressure? (Crazydave)
this reminds me of the time well maybe I should'nt say it oh well.
when I did a oil change and for some stupid reason forgot to put the cap on and I hear this load noise coming from the engine bay I'm like WTF so I turn off the car olny to see a bunch of fresh oil coming from you know where.
preetyboi06
Sep 18, 2012 12:18 PM
BodyKits NW
Oct 6, 2003 03:45 AM
98LS_VTEC
Aug 5, 2003 05:53 PM
r7
Aug 19, 2002 06:34 AM
Driven
Jan 4, 2002 01:35 PM
