oil pressure too high?
Old Aug 16, 2002 | 06:12 PM
r7's Avatar
r7
Default oil pressure too high?
is there such thing?
i get 70-80 psi @ 3000 rpm, idle at 20-25 psi
1990 b16a, pr3
Old Aug 16, 2002 | 07:05 PM
YTYPER's Avatar
Default Re: oil pressure too high? (r7)
That is normal! oil pressure will release at 80psi. when engine cold the pressure will be around 25 to 30 psi, when engine hot it will be lower around 20 psi. On the track after 10 laps, my ITR oil pressure is only around 15psi. That why good engine oil is very important.
Old Aug 16, 2002 | 08:06 PM
r7's Avatar
r7
Default Re: oil pressure too high? (YTYPER)
so, having a high oil pressure means my motor is good?
also, what oil should i run?
Old Aug 16, 2002 | 09:00 PM
Steve91's Avatar
Mine runs 80psi. Your fine.
Old Aug 16, 2002 | 10:42 PM
r7's Avatar
r7
Default Re: oil pressure too high? (Steve91)
thanks.. soo, now wtf is wrong with vtec ..
Old Aug 17, 2002 | 10:33 AM
YTYPER's Avatar
oil pressure will be release at 80psi. As long as it can release at 80 psi will be good.
I use redline oil every 4000 KM.
Old Aug 17, 2002 | 10:50 AM
r7's Avatar
r7
it does release.. . hm vtec still not working damnit
Old Aug 17, 2002 | 04:24 PM
YTYPER's Avatar
Do you have the oil pressure gauge on your car? You can see the oil pressure stay on 20-25psi while you idol, right. Then when accerate, the oil pressure will go up, until it reach 80psi, then oil pressure will go down. Oil pressure cannot go up too high.
Your vtec problem: That is what my question?
You buy a used engine right? it is a 1990 B16A?
Is it the vtec ecu? anything wrong of the ecu? Did you check the vtec solenoid inside, is it many carbon in it ? because if it is dirty, you have to clean it up and change the gasket too, that will cause the vtec doesn't kick in too.
Also check the timing and the condition of the engine carefully, because it is a pretty old used engine, you don't know how the engine inside will be?Also what people do on he engine before..
Old Aug 18, 2002 | 09:27 AM
r7's Avatar
r7
correct about the oil pressure.. it's good
anyhow
ecu good, vtec solenoid and oil pressure switch = good
since the oil pressure is good, i think the motor is good?
Old Aug 18, 2002 | 10:44 AM
YTYPER's Avatar
i think what i suggest maybe stupid. You can try to find another vtec solenoid (make sure it works), put it in your motor, see the vtec will kick in or not. If yes is easy, if still not kick in, maybe something wrong with the ecu or the wiring.
Old Aug 18, 2002 | 09:33 PM
r7's Avatar
r7
3 ppl checked wiring, all good
have tried 3 different pr3 ecu's
also unbolted vtec assembly, (solenoid, oil pressure switch) replaced with a known working one, same thing
Old Aug 19, 2002 | 06:34 AM
jweller's Avatar
check continuity of the wire between the ECU and the solenoid. check your grounds.
on2wheels
Jan 25, 2008 06:39 PM
bonylad
Sep 13, 2006 09:50 AM
LSVTECoupe
Aug 30, 2003 08:52 AM
