d16z6 throttle problems HELP ! ! ! ! !
so i have a turbo charged d16zz6 you guys. and my car starts to accelerate on its own somebody tolled me i had a bad butterfly but i was wondering the location of the butterfly in the car. the car also idles very high now it idles at like 2,500 rpms i was wondering why it did that i already screwed in the air idle screw on the intake as much as possible but it doesnt do anything really if i turn it out it idles evan higher than it used to. so can anybody attempt to help me??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HDizzle2478 »</TD></TR><TR><TD CLASS="quote">so i have a turbo charged d16zz6 you guys. and my car starts to accelerate on its own somebody tolled me i had a bad butterfly but i was wondering the location of the butterfly in the car. the car also idles very high now it idles at like 2,500 rpms i was wondering why it did that i already screwed in the air idle screw on the intake as much as possible but it doesnt do anything really if i turn it out it idles evan higher than it used to. so can anybody attempt to help me??</TD></TR></TABLE> The butterfly is that metallic thing the throttle cable is attached to. Try putting some dw40 or try adjusting the nuts on the throttle cable by the intake! Maybe your throttle isnt returning back properly
GOOD LUCK
GOOD LUCK
i had the same problem you should change your idle valve control and the idle screw on the intake manifold or just clean out the idle valve contol that should help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sittingon57cs »</TD></TR><TR><TD CLASS="quote">i had the same problem you should change your idle valve control and the idle screw on the intake manifold or just clean out the idle valve contol that should help </TD></TR></TABLE> Could be that to first check to see if your throttle returns all the way if it doesnt adjust your throttle cable like i said above if it is returning all the way then it might be you IAC. Meanin your idle air control valve which is stuck at the bottom of your throttle body! Take it offf and clean it
A high idle can be a vacuum leak or an IACV issue - though if it's accelerating on its own I'd say it's a stuck butterfly.
Spray some WD-40 or Silicone Spray in the hinge that the butterfly travels on, also on the outside where the butterfly rotor rotates on.
Also, make sure the inside of the TB isn't dented or damaged or anything preventing it from closing all the way. Also, make sure the throttle cable is adjusted right.
ok so i did the idle air control and it seems to be screwed in all the way and as for the throttle cable it moves in and out on its own.i have not taken the throttle body off and looked inside of it. I had a performance shop replace my thorttle body and now im accelerationg by myself so whatever was done 1 i dont know and 2 i know it has something to do with the throttle body i was tolled by a friend its prob my butterfly. Also the idling high part also is strange because my tuner tuned my car with the distributor totally advanced which i was tolled was very dangerous. but my car doesnt detonate. the other thing that i thought was strange is we retarted the distributor all the way back and it idles at 2 500-2000 rpms so im totally lost one person claims its the tune the other tells me its just a cable and a close friend who knows alot said its prob my butterly. so i guess the next thing to check is the butterfly. so how do i go about doing that i take off the throttle body completely and there is a metallic thing inside correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HDizzle2478 »</TD></TR><TR><TD CLASS="quote">ok so i did the idle air control and it seems to be screwed in all the way and as for the throttle cable it moves in and out on its own.i have not taken the throttle body off and looked inside of it. I had a performance shop replace my thorttle body and now im accelerationg by myself so whatever was done 1 i dont know and 2 i know it has something to do with the throttle body i was tolled by a friend its prob my butterfly. Also the idling high part also is strange because my tuner tuned my car with the distributor totally advanced which i was tolled was very dangerous. but my car doesnt detonate. the other thing that i thought was strange is we retarted the distributor all the way back and it idles at 2 500-2000 rpms so im totally lost one person claims its the tune the other tells me its just a cable and a close friend who knows alot said its prob my butterly. so i guess the next thing to check is the butterfly. so how do i go about doing that i take off the throttle body completely and there is a metallic thing inside correct?</TD></TR></TABLE>What do you mean by cable moves out on its own?
Don't just start messing with your distributor if you don't know what you're doing. Now you've screwed up the ignition timing. You'll have to take it somewhere and have it set to 16 degrees. If something is wrong with your engine, that may very well be fully advanced. Ignition timing affects idle speed. You can't just advance/retard the distributor w/out first jumpering the ECU into diagnostic mode.
You don't have to remove a throttle body to check/clean the butterfly.
You clearly have no clue what you are doing. I strongly recommend you not touch the engine and take it to someone that at least has a basic understanding and it willing to read a repair manual.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch »</TD></TR><TR><TD CLASS="quote">Don't just start messing with your distributor if you don't know what you're doing. Now you've screwed up the ignition timing. You'll have to take it somewhere and have it set to 16 degrees. If something is wrong with your engine, that may very well be fully advanced. Ignition timing affects idle speed. You can't just advance/retard the distributor w/out first jumpering the ECU into diagnostic mode.
You clearly have no clue what you are doing. I strongly recommend you not touch the engine and take it to someone that at least has a basic understanding and it willing to read a repair manual.</TD></TR></TABLE>
Not only that, but between setting a dizzy all the way advanced, and ******* up a throttle body install, it's pretty clear that the people he's taking it to have no clue what they're doing.
Find a new shop to take your car to. Stop taking it wherever you're taking it now - b/c they don't know what the **** they're doing. You shouldn't need to advance your distributor all the way, that's ridiculous.
well that was kind of rude bro i mean ya i really dont have a huge understanding like you guys to be honest so im humble and ask questions. im not arrogant about what i dont know but i can tell you i built the car myself. i I put the turbo kit on Myself and yes im not a genious im not certified its just something i love doing and also i did have a professional time it right and he said retarding it all the way was closest to the igniotion timing or w/e he used a timing gun with the flashing light. your correct i dont know everything. im trying to fix it on my own with help like people like you becuase i took it to 4 diff shops cause there are only 6 diff shops. one of them didnt evan know i had a bad distributor i fixed it lol it was the coil inside. one of em gapped my spark plugs at 25 i re gapped them at 35 and yes i did read a manual but i have a very elemantry understanding thats why im asking questions this is my project D series I also have a B16sir 2 i just baught amazing just to let you know and i just wanted some help cause nobody else seems to know what they are doing to my car one shop replaced my tranny and the car shut off right after i got outside cause they didnt know what they were doing it was some nasty wires that were exposed. and a dead battery and they couldnt evan tell me that so ya im not a freaking genious but im all i got so please dont put me down I AM TRYING SO YOU CAN HELP OR JUST LEAVE AND NOT POST ANYTHING IM SORRY I DIDNT KNOW WHAT THE BUTTERFLY WAS LOL LIKE GIVE ME A BREAK MAN IVE ONLY BEEN DOIN THIS HALF A YEAR AND BEFORE THAT I HAD NEVER USED A TOOL IN MY LIFE MR WHATEVER YOUR NAME IS ITS COOL AND IM NOT YELLING AT YOU IM MAKING A POINT. IM TRYING PERIOD AND I WANT TO FIX IT ON MY OWN CAUSE I ALWAYS END UP FIXING IT ON MY OWN ANYWAYS EVAN WHEN I DONT KNOW WHAT IM DOING BECAUSE I HAVE HELP FROM PEEPS LIKE YOU.
AND they didnt advance it all the way the retarted the distributor all the way . The car was tuned advanced by a street tuner. but it idled fine for atleast half a year i just started running into idle problems .
hidden sol
Oct 16, 2006 09:53 PM
