d16z6 swap HELLLLPPPP PLEASE IDLE IS REALLY BAD
Old Sep 6, 2005 | 09:53 AM
blindsk8er1013's Avatar
Default d16z6 swap HELLLLPPPP PLEASE IDLE IS REALLY BAD
hey guys im new to swaping motors. but me and my dad swapped in a d16z6 into my 92 cx. everything went smooth but when we started it up the idle was messed, it wennt up and down from 1k to 2k rpm. i cant seem to fix the problems. we changed out the tps and the idle steady out but it idles at 2500 rpm. wat could be the problem? please help me out. Im runing the si harness and a p28. if you guys could help me out it would be great thanks.
Old Sep 6, 2005 | 06:11 PM
Default Re: d16z6 swap HELLLLPPPP PLEASE IDLE IS REALLY BAD (blindsk8er1013)
can some one help me? ive replaced the the throttle body gasket, still nothing, check for leaks. still idles at 2500 rpms. PLEASE HELP???
Old Sep 6, 2005 | 08:13 PM
Syncmaster's Avatar
Clean out your iac valve... ALso check the throttle cable, make sure its moving smoothly and letting the throttle body close as much as it should.
Old Sep 6, 2005 | 08:58 PM
rev-speed's Avatar
unplug the iacv
if the car dies u have the wires cross
Old Sep 7, 2005 | 01:10 PM
unsungsohc's Avatar
Default Re: (rev-speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rev-speed &raquo;</TD></TR><TR><TD CLASS="quote">unplug the iacv
^^agreed and double check the the map and tps plugs are mixed up
Old Sep 8, 2005 | 06:57 PM
HondaCRX21's Avatar
throwing any codes?
Old Sep 9, 2005 | 06:13 AM
Sanda1s's Avatar
Default Re: d16z6 swap HELLLLPPPP PLEASE IDLE IS REALLY BAD (HondaCRX21)
Check for any vaccuum lines that may not have been hooked up put your finger over the end to see if the idle drops. If you can not find where it goes just plug it with something.
Old Sep 9, 2005 | 08:28 AM
thanks for the advice guys, ill give it a shot again.
Old Sep 11, 2005 | 06:35 PM
crxfornow's Avatar
if none of those opinions worked i bet you have a automatic intake manifold i cant remember what the difference is but you have to convert something to three wire instead of two wire i just cant remember maybe someone will finish what i started to say
johnp88gt
16
Jun 14, 2011 06:42 PM
Jonathan_ED3
Jan 13, 2009 03:15 PM
hocivic95
Oct 13, 2008 04:12 PM
blindsk8er1013
Sep 6, 2005 07:32 PM
QWKPHKR
Oct 8, 2002 06:37 PM
