How do I know if my water pump is going bad?
Old Jun 12, 2002 | 04:44 AM
Home Skillet's Avatar
Default How do I know if my water pump is going bad?
I've noticed that when I drive for more than 30 min my temp will go higher than normal. I flushed my coolant and had the same results. My fan is wired to the ignition so it's on whenever my key is in the "ON" position. My car still overheats but it's not that bad yet now since the temp does go down when I turn on the heater. But i do want to correct this problem early before anything else happens. Has anyone had this problem or know what to do?
Old Jun 12, 2002 | 06:46 AM
spettinger's Avatar
Default Re: How do I know if my water pump is going bad? (Home Skillet)
it will be easier to check your thermostat first, underneath the throttle body side of the intake manifold. i would replace that first, if no improvements, then i would check the water pump. it should not be too easy to turn, if you hold it close you should be able to hear it squeak when it turns. what motor?
Old Jun 12, 2002 | 06:49 AM
Default Re: How do I know if my water pump is going bad? (wreckedhatch)
it will be easier to check your thermostat first... what motor?
dag, i must be losing my troubleshooting techniques. computer related jobs do have its downside. i didnt even bother checking that yet, thanks mang. i got a b16 in there right now.
Old Jun 12, 2002 | 09:47 AM
Renegade's Avatar
You can also go to a local radiator shop. Out here we have a place called Radiator Land that does a complete check and tell what is wrong for $25 USD.
Old Jun 12, 2002 | 09:57 AM
d-wreck's Avatar
Default Re: How do I know if my water pump is going bad? (98401R)
sounds like a bad thermostat
or you have a broken water jacket when running 2bars of boost yesterday.
derek
Old Jun 12, 2002 | 10:00 AM
DJ KrunchyKracker's Avatar
Default Re: How do I know if my water pump is going bad? (d-wreck)
i wish i could run 2 bars of boost. actually i wish i could run a half bar. or a half of a half. or a half of a half of a half
Old Jun 12, 2002 | 10:54 AM
uh, yeah umm, i wish i had boost.
Old Jun 30, 2002 | 01:53 PM
blacksoul's Avatar
My car does this same thing! Did you ever find out what the problem is?
I just did a search, and this came up, so i decided to post.
I have a new thermostat, so that shouldnt be the problem. My guess is it's either the radiator of water pump.
Old Jun 30, 2002 | 02:02 PM
USDM 4G VTEC's Avatar
check thermosthat
check that ur radiator doesnt have any clogged lines...
if the pump goes bad, u going to be leaking water tru the front.... but sounds more like thermosthat... check that
peace
Old Jan 17, 2004 | 02:06 PM
sparxx's Avatar
your fan is on all the time?is the fan blowing towards the front of the car or into the car....if it's blowing away from it you should put a switch on your fan to turn it off during highway driving...
Old Jan 17, 2004 | 07:15 PM
Default Re: How do I know if my water pump is going bad? (sparxx)
Holy Post Revival!! This was 2 yrs ago. Well, since then I've swapped in another B16A in the hatch and found out it was the thermostat that was crusted up. btw, the fan blows towards the motor.
Old Jan 19, 2004 | 05:55 PM
sparxx's Avatar
word
NOTUNINGNONADA
Jul 18, 2010 06:28 AM
prettyinpink
Oct 16, 2007 03:23 PM
dc2415
Jul 1, 2007 08:51 AM
christiian
18
Jul 16, 2006 12:03 AM
richboi
Mar 25, 2006 04:41 PM
