Stock B16 + SC61 = 7psi @ ????RPM
Old Aug 9, 2007 | 07:49 AM
JordanCivic's Avatar
Default Stock B16 + SC61 = 7psi @ ????RPM
^Could u work that out?? LOL
I got a Stock B16a2 with a SC61 and log mani, 3" full exhaust.
When should i expect to hit 7psi ( set by WG )??
Seems to be around 5300rpm, this sound normal? Would have thought a little lower.
Anyone with a simular setup have any bhp/tq figure or trap times?
Thanks
Old Aug 9, 2007 | 08:11 AM
alpha's Avatar
Default Re: Stock B16 + SC61 = 7psi @ ????RPM (JordanCivic)
That sounds about right. I would have to look through my logs to know for sure
Old Aug 9, 2007 | 09:05 AM
93CX's Avatar
Default Re: Stock B16 + SC61 = 7psi @ ????RPM (alpha)
SC61 seems to spool very slowly, why is this?
Old Aug 9, 2007 | 09:09 AM
ghostskinner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX &raquo;</TD></TR><TR><TD CLASS="quote">SC61 seems to spool very slowly, why is this?</TD></TR></TABLE>
because it is a big turbo
Old Aug 9, 2007 | 12:02 PM
quicksilver1689's Avatar
i ♥ snails
for sure, non bb large turbo
Old Aug 10, 2007 | 01:28 AM
Thanks guys, just wanted to see if it sounded right.
Any Trap times with this setup?
I will be building in near future, hence the SC61.
Old Aug 10, 2007 | 07:52 AM
alpha's Avatar
Default Re: (JordanCivic)
Looked through some of my logs. 8lbs from 4800RPM - 5300RPM on all the 1.6 liters
Old Aug 10, 2007 | 07:56 AM
Thanks for that, im using 2.5" IC piping and a big cooler so i can expect the upper end of that range i would imagine, which it seems to be doing.
Thanks again guys
Old Aug 10, 2007 | 09:37 AM
Joseph Davis's Avatar
7 psi on such a small engine, so late in the powerband, means it's going to fall off like hell whenever you shift. Unless you're busting the hell out of every gear trying to break your transmission.
You need 16-18 psi minimum to be happy with that turbo.
Old Aug 10, 2007 | 09:49 AM
Schister66's Avatar
Man U FTW
Why the hell do people chose turbos that are 4 times larger than what they need....if you want a car that makes power from 6500 rpm and on, then this is a great setup...if you want something that doesn't suck, look around a little more before chosing a turbo.
An SC61 can support 550+whp and you're not going to be near its efficiency range. Most people dont understand how to decide on turbos and rather than learning, just follow a bandwagon. That's why the GT35r is so popular...even on setups where it is less than 1bar. If you're looking for a fun setup on a street car, get a 3bar map sensor, a good tuning software, a GT3251b and run 14psi...you'll make a good amount of torque, have full boost before 4k rpm, and have power through redline.....AND still spend less money than the SC61
if you want to look into that last option more, PM me and we'll talk...
Old Aug 10, 2007 | 09:54 AM
Hang fire!!
I did state in a previous post that 'the motor will be built, hence the sc61'. I have a 1.7L motor being built that will be running 1.5bar.
I understand there will be alot less lag with a GT BB turbo, and if/when i upgrade i will be going down that route.
Old Aug 10, 2007 | 10:06 AM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JordanCivic &raquo;</TD></TR><TR><TD CLASS="quote">I understand there will be alot less lag with a GT BB turbo, and if/when i upgrade i will be going down that route.</TD></TR></TABLE>
Another common mistake...there isn't a significant amount less lag w/ the GT-R series, they are generally better engineered turbos that have a lot lbroader efficiency range. The turbos are designed around the BB CHRA...dont start thinking that it is the BB CHRA that does all the work. Converting a turbo to a ball bearing center cartridge WILL NOT improve spool, it will only help in transient response.
Old Feb 27, 2008 | 07:51 PM
MidwestAutoWorks's Avatar
Default Re: (Schister66)
How would this sc61 spool on a 2.3 liter
Old Feb 28, 2008 | 08:11 AM
TheShodan's Avatar
Moderator
Default Re: (MidwestAutoWorks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestAutoWorks &raquo;</TD></TR><TR><TD CLASS="quote">How would this sc61 spool on a 2.3 liter</TD></TR></TABLE>
Better than 1.7litre with no stroke to the displacement...
Old Feb 28, 2008 | 10:47 AM
tony413's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">Why the hell do people chose turbos that are 4 times larger than what they need....if you want a car that makes power from 6500 rpm and on, then this is a great setup...if you want something that doesn't suck, look around a little more before chosing a turbo.
if you want to look into that last option more, PM me and we'll talk...</TD></TR></TABLE>
i like your sales technique . i guest YOU'RE offering the turbo cheaper than a SC61. because i have never seen ANY BB turbo cheaper than $800 new
Old Feb 28, 2008 | 12:41 PM
Schister66's Avatar
Man U FTW
Default Re: (tony413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">
i like your sales technique . i guest YOU'RE offering the turbo cheaper than a SC61. because i have never seen ANY BB turbo cheaper than $800 new</TD></TR></TABLE>
The GT3255b is not a ballbearing turbo. Ballbearing GT series turbos are denoted GT-R. Also, you dont need a BB CHRA to spool fast...people really misunderstand the benefits of them
Old Feb 29, 2008 | 11:30 AM
.:si:.'s Avatar
i was hittin full boost about 4500 with a sc61...stock
Old Feb 29, 2008 | 03:34 PM
Tjabo's Avatar
Is it correct that this GT325xb is similar to an SC61 with an older spec turbine wheel, or is that something else? I can't keep it all straight.
Old Mar 1, 2008 | 09:49 PM
tony413's Avatar
The GT3255b is not a ballbearing turbo. Ballbearing GT series turbos are denoted GT-R. Also, you dont need a BB CHRA to spool fast...people really misunderstand the benefits of them</TD></TR></TABLE>
i dont use BB turbos because the cost for me do not outweight the benefits.
scuffywin
Jul 5, 2007 01:16 PM
Boner_Ben
Jul 2, 2006 09:40 AM
Equilibrium
Jul 1, 2005 09:13 PM
meanB6teen
May 10, 2005 07:56 PM
Leo_Multi
17
Jan 12, 2004 01:32 PM
