b18c rebuild
Old Jun 11, 2002 | 09:20 PM
Madness's Avatar
Default b18c rebuild
ok-- trying to decide whether to rebuild my b18c before going turbo @ 85k
what should i replace if i do?
rings
rod / main bearings
gaskets (duh)
what else?
experienced peeps give me some pointers -- this is my first rebuild and i don't want to get involved and find out i have to wait 2 months to special order a
$5 piece
thanks,
josh
Old Jun 11, 2002 | 09:41 PM
Kataku2K3's Avatar
Default Re: b18c rebuild (dante_420)
Forged pistons, rods, bearings, and if you plan on boostin a lot have the block resleeved. My friend has a GSR bored .25 over with 9.0:1 JE's, rods (I'm not sure what brand), Portflow head, B16A cams, Sprockets, RC 440 injectors, Hondata 4b, and a Revhard T3/T04E hybrid turbo. The thing boosts hella crazy. It's in a 97 HX and should be pulling low 12's to high 11's this saturday. It's gonna be fun.
Old Jun 11, 2002 | 09:49 PM
Madness's Avatar
Default Re: b18c rebuild (JDMspecEG6)
b16a cams? wtf am i missing?
and yes pistons and rods are definately in the works
i need some hardcore opinions <U>please!</U>
Old Jun 12, 2002 | 12:47 AM
KTeller8's Avatar
why rebuild buy this from me
Full build SOHC from for 2700
srp pistons, 9:1 compression, eagle rods, blockguard, unorthodox crank pulley
the head is ported and polish, ferrea valves, webcamic springs and retainers .. aem cam gears.. rebuilt tranny with LSD quaife.. act clutch, cluthnet flywheel
mkteller8@aol.com
Old Jun 12, 2002 | 07:54 AM
Madness's Avatar
Default Re: b18c rebuild (KTeller8)
sohc into a gsr?
no offense, but i think <U>not</U>
Old Jun 12, 2002 | 09:00 AM
Spike2's Avatar
obviously you are gonna have to replace the rings. With 85K you are gonna have to replace all the bearings also. go ahead and replace the timing belt and prolly headgasket too. It wont be too cheap, but better that risking something breaking.
Where are you getting your stuff done at? I got mine done at Pattersons and they do some good work, for pretty cheap too.
Old Jun 12, 2002 | 01:30 PM
Madness's Avatar
Default Re: b18c rebuild (Bob Ross)
hey thanks for the input (bob ross)
i'm actually out-of-state right now
so i'll be doing most of the build myself
(have actually heard of Pattersons though)
i'm thinking oil pump and water pump also?
Madness's Avatar
anyone else? there's got to be something i'm missing
Old Jun 12, 2002 | 01:38 PM
Rocket's Avatar
Just get some nice engine building tools like torque wrench ready, assembly lube, ring compressor, engine stand, Hondabond, plastigauge, etc.
Also rods go in a certain way... That you can take care of when you are doing the assembly.
Make sure all parts are absolutely clean and dust/particle free and you should be set.
Old Jun 12, 2002 | 02:03 PM
Madness's Avatar
Default Re: b18c rebuild (Rocket)
rocket -- remind me to buy you a if we ever meet up
you're turning out to be a great source of info!
Old Jun 12, 2002 | 02:16 PM
builthatch's Avatar
MiG-21 superfan
don't forget...HELMS MANUAL, A GOOD MACHINIST, AND PATIENCE...the helms manual will thoroughly explain all the necesities and what should be replaced/re-used, ie. torque sequences, torque settings, washers, gaskets, etc...balance it, make sure all your clearances are PEFECT, and don't cut corners with time or $.
[Modified by builthatch, 6:17 PM 6/12/2002]
Old Jun 12, 2002 | 02:44 PM
Rocket's Avatar
That's what I like to hear. We all know how much we like Honda performance so it's no sweat.
Keep on boarding!
Old Jun 12, 2002 | 06:41 PM
Madness's Avatar
Old Jun 12, 2002 | 09:10 PM
Spike2's Avatar
no need to replace the water or oil pump unless they were broke before hand.
Be careful getting everything back on right, and definately get a Helms. Hondabond is the **** too
ll Del La Sol ll
May 16, 2005 08:54 PM
madtownhonda
Apr 9, 2004 09:09 PM
turbopanda
Dec 4, 2002 01:10 AM
turbopanda
Sep 16, 2002 12:11 PM
tinkerbell
Jan 7, 2002 08:56 AM
