Just retarded my timming...suggestions.
setup: 2000 ITR with drag 3 kit..wast gate set at .3 bar (4.35) psi...just wanted comments from you that retarded your timming or left it at stock settings.
Good or bad??
Good or bad??
I would like to know how to retard timing.....
When you say "don't retard it more than 2 degrees" do you mean 2 degrees absolute retard, or two degrees subtracted from the 16 advance (ie. total advance of 14 degrees)? Is there a way to accurately do this with just a regular timing light, one without a ****?
Stock timeing marks(on the crank pulley) are stock, +2 and -2, so if you wanted to retard 2 degrees, it would be one of the marks on the crank pulley(The one closest to the TDC mark).
B18C timing marks:
B18C timing marks:
Art why did you do that? don't you let Hondata retard in boost only? I leave my distributor advance at stock of 16. I run 0.75 retard per pound of boost and will likely lower that to 0.5. That means at 10psi I will be 5deg retard vs stock (which is about 21 deg total advance at 10psi and 7000rpm.
art
i retarded the timing two degrees on my gsr (just in case).. i can do it for your itr if you want. just call me up mark
(this is steve)
(this is steve)
civic j
Aug 17, 2007 08:10 AM
the.hamburglar
Sep 25, 2005 08:32 AM
handa
Oct 24, 2004 08:27 AM
