Question's on engine build...
Old Jun 16, 2002 | 05:06 PM
*Boostwerks*'s Avatar
Default Question's on engine build...
How do I go about...
-Determing exactly what Bore piston I should buy? Is it safe to say that a low mileage ZC is going to need the stock 75mm bore?
-Determining what size berrring's I need. Do I use the old berring's with my new Crower's and do the whole plastigauge thingy?
-How do I tell if a Water pump need's replacing(with out running the motor)
-" same question "....Oil pump.
-Do I need to replace the Crank Thrust berring's?
I feel confident in most of the awnser's to those question's, but I just want to make sure, and also get some opinion's/experiences.
Thank's for any help
Old Jun 16, 2002 | 06:39 PM
Default Re: Question's on engine build... (Bryson)
NE body?
Old Jun 16, 2002 | 06:44 PM
b18b98's Avatar
you might as well replace the water pump and oil pump unless this motor is mint.
Old Jun 17, 2002 | 08:52 AM
downpipe's Avatar
Default Re: Question's on engine build... (b18b98)
i would replace the water pump, and get new bearings. you will have to size the bearings correctly, yes...i don't know if its the same on that motor but on my b18c1 there are codes on the block and on the crank which tell you which size bearings you need...then when you reassemble you need to platiguage them to make sure the tolerances are correct. and i'd get a new oil pump gear...prodrive if they make em for that motor.
thrust washers are cheap, replace them too. also, depending on how old this motor is, you shoudl consider doing the timing belt, upper and lower gaskets and seals, etc etc.
[Modified by downpipe, 9:54 AM 6/17/2002]
Old Jun 17, 2002 | 10:14 AM
Default Re: Question's on engine build... (downpipe)
well this is a FULL rebuild. so I'm going to replace any thing that should be replaced while the engine is out.
I think I am going to take my time and tolerance everything...instead of just using the code's fallowed up with plastigage.
Anyone have problem's with lot's of HP...caused by using just normal code/plastigauge techniques?
Old Jun 17, 2002 | 10:21 AM
dustin's Avatar
Yes, go with stock bore.
Read the marks on the crank, and cross reference with the sizing of your rods for the rod bearings. Main bearings, you can probably just buy the colors that are already in the block. Plastigauge everything.
Just replace the water pump. Oil pump is probably fine.
They're probably ok.
Dustin
Old Jun 17, 2002 | 10:34 AM
Default Re: Question's on engine build... (dustin)
well would you still agree on those point's if I told you the motor is going to have around 350-400HP??
Old Jun 17, 2002 | 10:35 AM
dustin's Avatar
hehe, ZC on stock sleeves? I'd still agree but I would sleeve the block first
Old Jun 17, 2002 | 11:29 AM
93LSivic's Avatar
Is this chart anywhere on the web? Say for an LS..
Old Jun 17, 2002 | 12:01 PM
dustin's Avatar
Default Re: Question's on engine build... (93LSivic)
Old Jun 17, 2002 | 12:28 PM
downpipe's Avatar
damn dustin, you scanning maniac. i was just gonna tell him to buy the book.
if that book doesn't look familiar, buy one !
Old Jun 17, 2002 | 12:34 PM
93LSivic's Avatar
Thanks Dustin. I remember you sharing these pics a couple of weeks ago and forgot to save them.
I really do need to get a helms, but that $60 can go towards my buildup
Old Jun 17, 2002 | 12:35 PM
dustin's Avatar
ahah I "scanned" those with my digital camera
<-- lazy
93HatchDreams
Jun 30, 2014 03:35 PM
rob42386
Nov 26, 2004 07:22 PM
Pfieff
Dec 10, 2003 08:14 PM
*Boostwerks*
Jun 16, 2002 07:10 PM
