LS turbo guys. Vtec oil pump?
Old Aug 5, 2007 | 05:13 PM
hydroflip's Avatar
Default LS turbo guys. Vtec oil pump?
i noticed in my helms that the GSR pump pushes out a significant amount of oil, more than the LS. i did a search and also noticed that a couple people have done this swap. is it beneficial?
i'm at about 100k and figured i could replace my oil pump since they would do the timing belt anyway.
is my current oil pump ok with the age or should i go ahead and do it?
stock LS pump or VTEC pump?
Old Aug 5, 2007 | 05:36 PM
adseguy's Avatar
Default Re: LS turbo guys. Vtec oil pump? (hydroflip)
Might as well throw the GSR pump in there. It's made to handle higher revs then the LS was intended for.
Old Aug 5, 2007 | 06:59 PM
tony413's Avatar
go ahead an do it also look in the replacing the water to a GSR also an use a GSR timing belt
you can get everything for around $260-$300
Old Aug 5, 2007 | 09:28 PM
JDMs1eeper's Avatar
believe, 96+ all had the same oil pump. just switch out to a newer.
Both vtec and non.
Old Aug 6, 2007 | 08:20 AM
da_dude's Avatar
Default Re: LS turbo guys. Vtec oil pump? (JDMs1eeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMs1eeper &raquo;</TD></TR><TR><TD CLASS="quote">believe, 96+ all had the same oil pump. just switch out to a newer.
Both vtec and non.</TD></TR></TABLE>
Yes, it's true.
Old Aug 6, 2007 | 01:43 PM
redlsvtec4door's Avatar
btw a gsr timing belt and a ls timing belt are not the same size. get the ls if you have a ls. and it not going to be stronger if it gsr or type r.
Old Aug 6, 2007 | 02:07 PM
StolenTeg's Avatar
Default Re: LS turbo guys. Vtec oil pump? (redlsvtec4door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlsvtec4door &raquo;</TD></TR><TR><TD CLASS="quote">btw a gsr timing belt and a ls timing belt are not the same size. get the ls if you have a ls. and it not going to be stronger if it gsr or type r.</TD></TR></TABLE>
Timing belt choice depend on which water pump you are using
BuddhaSiR
Aug 16, 2006 11:29 AM
astralshadow
Jun 12, 2006 06:38 PM
Mugencrxsir1
Apr 25, 2006 03:02 PM
VWkila
Jan 29, 2003 02:09 PM
X2BOARD
Apr 16, 2002 12:26 PM
