My Tuner Says 8pds?
Old Aug 3, 2007 | 10:39 AM
00garrettsi's Avatar
Default My Tuner Says 8pds?
i tuner says i have to run 8pds of my stock block b16a2 is that true for A T3/T4 turbo?
DaveF's Avatar
Default Re: My Tuner Says 8pds? (00garrettsi)
tell your toooner he needs to get out more !
Old Aug 3, 2007 | 10:55 AM
SD_Lurker's Avatar
HT White Ops
Default Re: My Tuner Says 8pds? (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">tell your toooner he needs to get out more ! </TD></TR></TABLE>
better yet, fiind yourself another tuner!
Old Aug 3, 2007 | 10:57 AM
Default Re: My Tuner Says 8pds? (SD_Lurker)
what should i run then?
Old Aug 3, 2007 | 12:32 PM
awdgsx96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00garrettsi &raquo;</TD></TR><TR><TD CLASS="quote">i tuner says i have to run 8pds of my stock block b16a2 is that true for A T3/T4 turbo? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00garrettsi &raquo;</TD></TR><TR><TD CLASS="quote">what should i run then?</TD></TR></TABLE>
Hooked on phonics
But seriously, what is your question?
Old Aug 3, 2007 | 12:42 PM
DaveF's Avatar
350hp-pumpgas.
Old Aug 3, 2007 | 02:02 PM
he said 8pds is enough to get me 250
Old Aug 3, 2007 | 02:44 PM
k24em2's Avatar
Default Re: (00garrettsi)
You need to go back to high school.
You are running 8 PSI, not 8 PDS. That is Pounds per Square Inch.
Old Aug 3, 2007 | 03:03 PM
Tulo's Avatar
What does pds mean?
Old Aug 3, 2007 | 03:12 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00garrettsi &raquo;</TD></TR><TR><TD CLASS="quote">he said 8pds is enough to get me 250</TD></TR></TABLE>
Can you tell us your setup.
Old Aug 3, 2007 | 03:17 PM
njn63's Avatar
Default Re: (Tulo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tulo &raquo;</TD></TR><TR><TD CLASS="quote">What does pds mean?</TD></TR></TABLE>
I assume it's an attempted abbreviation at "pounds" which actually should be lbs or more accurately PSI because that is what is actually be measured.
Old Aug 3, 2007 | 05:20 PM
boostismycrack's Avatar
E-thug
Default Re: (Tulo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tulo &raquo;</TD></TR><TR><TD CLASS="quote">What does pds mean?</TD></TR></TABLE>Pretty dumb speller, lol.
Old Aug 3, 2007 | 05:23 PM
boostedcivicsir's Avatar
Mr. Badwrench
6 was enough for 230 on my lower than stock compression pig rich b16.
Old Aug 3, 2007 | 05:39 PM
integraRS-T's Avatar
if he scored a not to good compresion test it wouldnt surprise me he only daid 8psi
Old Aug 3, 2007 | 06:15 PM
rmcdaniels's Avatar
You can run 30 PSI if you want. Of course your **** will blow up, but if that's what you want.................
There are a lot of factors that go into how much PSI you can run. Maybe your tuner is just conservative and looking to keep your motor as reliable and long-lasting as possible. Maybe there is some other limiting factor to your setup, like the injectors or compression. Ask your tuner why he doesn't want to run more than 8 PSI. If he won't talk to you about it, then it may be time for a new tuner.
Old Aug 5, 2007 | 04:37 PM
ok for one even if a guy on ht makes a mistke correct it and move on dont bash it and yes my tuner said 8PSI and i talked to him recently and he explained he is going to tune it to that to keep its everyday reliability
Old Aug 5, 2007 | 05:12 PM
awdgsx96's Avatar
Sounds better
Old Aug 5, 2007 | 08:20 PM
project dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00garrettsi &raquo;</TD></TR><TR><TD CLASS="quote">ok for one even if a guy on ht makes a mistke correct it and move on dont bash it and yes my tuner said 8PSI and i talked to him recently and he explained he is going to tune it to that to keep its everyday reliability</TD></TR></TABLE>
just to give you a tip. please be specific when asking questions with good details.
i hate it when someone PM's me and says " is this still for sale?" when i have a million sponsor special prices posted up.
youll get bashed on honda-tech for being vague.
ek9child
May 26, 2007 10:59 AM
Humble Performance
Nov 28, 2006 06:12 PM
97_delsol_Vtec
May 9, 2006 04:51 PM
kcjohnnyboy
Jan 25, 2006 10:58 AM
2point2
Welding / Fabrication
Oct 11, 2004 08:09 AM
