b20 vtec turbo setup
Old Aug 5, 2007 | 07:35 PM
Leef9turbo
Guest
Posts: n/a
Default b20 vtec turbo setup
Debate. I just finished putting together my Crvtec. Basic. B20z bottom end 100% stock, B16a 1rst gen head, mild bowl work, and port matched, 3 angle, and worked stock manifold, gsr throttle body.B16 cable nonlsd/ 4 puck clutchmasters. Ok also have turbo kit. Basic log/ 35mm Deltagate/ rear inlet/ outlet intercooler Spearco core/ stock supra bov/ oh yeah t3 .42/.48 air research/ 3" stainless dp/ open wg dump.. Debate. Keep it all motor because I have b16 trans and am afraid any more than na and I will wheel spin the 1/8 OR....Boost it 5-7 pounds mild tune and deal with it. My ef has poly radius rod/ front lca bushings and sk2 drag coilovers. Car will be obd1 either way so not a factor neither is tuning. Thanks
Old Aug 5, 2007 | 08:15 PM
Leef9turbo
Guest
Posts: n/a
Default Re: b20 vtec turbo setup (Leef9turbo)
replies?
Old Aug 5, 2007 | 08:22 PM
philafelman's Avatar
if the transmission is the only thing holding you back from boosting, get a different tranny...i would think the lower compression b20 block would favor it anyways.
Old Aug 5, 2007 | 08:30 PM
Leef9turbo
Guest
Posts: n/a
Default Re: b20 vtec turbo setup (philafelman)
tranny isn't just it. B20 will only hold low boost in stock form aka weak sleeves. So really just debating is the 5- 7 psi worth the stress on the sleeves/ drive line?
urtz
Jan 20, 2007 09:02 PM
Scantron
Mar 17, 2006 02:32 PM
tmramsburg
17
Jan 7, 2006 11:11 AM
respectblades
May 29, 2003 03:17 PM
2SLO
Nov 6, 2002 10:47 PM
