turbo trim question
Old Jan 20, 2006 | 07:43 PM
kcjohnnyboy's Avatar
Default turbo trim question
this dude is selling a garrett t3 turbo. he says the trim is "a/r.60 a/r.98" i dont understand what that means or if he is even right. i thought the a/r was the width of the turbo and compressor or something like that. also isnt the trim totally different from the a/r? if u can help me out that would be great thanks
Old Jan 20, 2006 | 07:57 PM
93turbo16's Avatar
See below.
Modified by 93turbo16 at 1:17 AM 1/21/2006
Old Jan 20, 2006 | 08:30 PM
1dumbscreenname's Avatar
Default Re: (93turbo16)
that seems really huge to me.
Old Jan 20, 2006 | 08:34 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">Trim is different than the a/r.
Yes
The a/r is like exducer/inducer or something to that effect.
Trim is basically the size of the housing.</TD></TR></TABLE>
No.
Old Jan 20, 2006 | 09:08 PM
93turbo16's Avatar
Default Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">
No. </TD></TR></TABLE>
I was just going from memory there, don't just say no. That is a stupid response. Correct my error would be a lot more informative. I forget things like this on a daily basis no matter how many times I read them. Help me out here.
Alright did a little reading. Let me see if this is correct, the trim size is determined by the inducer and exducer of the compressor wheel and the A/R is more like this
"(A) and the distance from the center of the "tube" to the turbine shaft (R). The values by themselves are not meaningful to the user and for the most part, R does not change much for different housings, but by dividing R into A, you get the A/R ratio. So, the A/R ratio of the exhaust housing refers to the size and shape of the scroll that is cast into the housing. It basically determines how restrictive the housing will be, versus how quickly the turbine will spin up."
Old Jan 21, 2006 | 06:33 AM
Bailhatch's Avatar
sorry i was short on time. The thing with either of those specs is that they don't really tell you much without knowing the wheel sizes. It all relative. Generally though you find the bigger T3 compressor wheels in a .60 a/r cover so maybe its a a 60trim or something, as for the .98 a/r i have never seen that number on a t3.
Old Jan 25, 2006 | 10:58 AM
Default Re: turbo trim question (kcjohnnyboy)
thanks for the help. so what trim do u think the turbo is?
cleanej2
Oct 20, 2008 03:56 PM
95exdsmkilla
Aug 14, 2008 05:30 PM
ek9child
May 26, 2007 10:59 AM
2point2
Welding / Fabrication
Oct 11, 2004 08:09 AM
racinskittle
Jun 2, 2003 08:42 PM
