Help guys...Car wont start
Old Aug 3, 2007 | 10:12 AM
scrn07's Avatar
Default Help guys...Car wont start
So i am thinking of changing out my plugs, wires, now I dont know whether to change my distributor cap and rotor?? or the whole distributor assembly??
WHat you guys think...and Im also thinking of changing out my fuel filter.
Thanks guys
Old Aug 3, 2007 | 10:14 AM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: Help guys...Car wont start (scrn07)
Same post #501 in the same week...
Did you atleast test your battery???
Old Aug 3, 2007 | 10:15 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: Help guys...Car wont start (Project95LS-VTEC)
What happens when you try to start it? Are you getting fuel? Spark? Compression? Is it even turning over?
Old Aug 3, 2007 | 01:44 PM
scrn07's Avatar
yes it was cranking but nothing..but now it wont even crank..so I think the battery is dead.
But when this first happen dI was driving and it stalled. Then I tried turning on and it would crank but wouldnt start..So what u guys think?
Old Aug 3, 2007 | 04:35 PM
boostedgsr1234's Avatar
Default Re: (scrn07)
check coil in the dizzy., fuel pressure, frul filter, easy check for spark. take a plug out and put it in the plug wire and ground the threads of the plug and turn the engine over if there is a spark at the plug then that just means ur getting spark GOOD LUCK
Old Aug 3, 2007 | 04:42 PM
Brian2.0's Avatar
when it first happened did it just stall out? did it studder a bit then just kinda die in a weezing type gasp? any sputter? when you get it to turn over will it crank and run if you pump the gas the whole time?
Old Aug 3, 2007 | 06:42 PM
B18 Piston's Avatar
Old Aug 4, 2007 | 07:16 AM
St Jimmy's Avatar
* B A N N E D *
sounds like your alternator went out and ended up killing your battery. Recharge battery and buy new alternator, or brushes (inside the alternator) if thats whats wrong.
gerbsgsr
15
Dec 28, 2015 08:46 PM
fooboo
May 22, 2010 01:53 PM
CuteAccord
37
Jan 3, 2009 10:41 AM
GoldCoin
Aug 21, 2006 06:29 PM
TheAntiEndz0r
10
Aug 26, 2003 07:15 AM
