T3/T4 T04B and T3/T4 T04E and intercooler
Old Jun 10, 2002 | 10:02 PM
joek84's Avatar
Default T3/T4 T04B and T3/T4 T04E and intercooler
what's the difference between these two turbos. Which would be better for my gsr setup. Im thinking of running at 5 psi and 8 psi on high boost. what size or type of intercooler do you guys recommend for either turbos.
Old Jun 10, 2002 | 11:39 PM
shadowdawn's Avatar
Default Re: T3/T4 T04B and T3/T4 T04E and intercooler (joek84)
A friend of mine has the b, I have the e...... he is stick, I'm auto, but I still think my car pulls harder then his..... then again the E is bigger and flows more...
Power for power the E is the best bang for the buck..... the B is just smaller and flows less
FYI friend with the B spools only 200rpm quicker then mine and he has 3" exhaust, my exhaust is completly stock and I hit full boost around 4200rpm..... I run 7psi and does he.
Old Jun 11, 2002 | 01:42 AM
CalvitoSol's Avatar
Default Re: T3/T4 T04B and T3/T4 T04E and intercooler (shadowdawn)
hey joe, i'm wondering how you can tell if the turbo is good or not? i'm considering on buying a t3/t4 t04e too but not sure if it's in good cond. i check for shaft play and its solid. how bout the turbine spin? how smoothly is it supposed spin? i've heard that the fins spin if you blow on em, is that true? the one i'm looking at spins maybe about 3 or 4 rotations when i spin it with my fingers. is this ok? thanx
Old Jun 11, 2002 | 02:04 AM
boostedhb's Avatar
The B is mainly used for sohc. And the e is more for dohc. So you would be better off going with the t3 to4e and fmic.
Old Jun 11, 2002 | 05:14 AM
TypeC's Avatar
Holy $hit, that's some lag!! How can you guys (1.8 with big turbos) deal with that?
-C
Old Jun 11, 2002 | 02:33 PM
Xerxes's Avatar
New User
Default Re: T3/T4 T04B and T3/T4 T04E and intercooler (TypeC)
4200rpm full boost ain't bad if you're redlining at 8000
-Xerxes
Old Jun 11, 2002 | 03:06 PM
Etylorcen's Avatar
Default Re: T3/T4 T04B and T3/T4 T04E and intercooler (Xerxes)
When you get snapped back in your seat you realize the wait for was it "If you have no lag you have no turbo at all." - Corky Bell
Old Jun 11, 2002 | 03:19 PM
FredoSP's Avatar
Default Re: T3/T4 T04B and T3/T4 T04E and intercooler (Etylorcen)
This Topic was covered before by me, search under my username, you'll get something, trust me
punkracer
May 2, 2011 07:38 AM
turbodailydan
Nov 29, 2009 09:52 AM
DJaeMac
Honda Civic (2001 - 2005)
Sep 21, 2007 09:45 AM
Azndude1983
Feb 7, 2006 10:26 PM
Stock@$$GSR
May 24, 2002 02:54 PM
