dseries built turbo setup how much power can i make?
Old Jul 30, 2007 | 12:28 PM
MBlake55's Avatar
Default dseries built turbo setup how much power can i make?
I was just wondering how much power i could make with my current setup because someone told me only 250 and i was like NO WAY
d16y8 bored and honed .040 over
- 9:1 JE pistons w/ Eagle rods
- ARP head bolts
- Head is resurfaced and polished
- brand new gaskets
- performer x intake manifold
- (I have the edelbrock kit)...... t28 turbo ball bearing brand new, dsm 450s, tuned on chrome at 15 psi but no dyno runs yet, 2.5" exhaust, internal wastegate, tial sequential BOV, spearco intercooler
I was thinking i could make at least 270-280 wheel horse and i was just wondering wat other people think or if anyone disagrees with me or any suggestions thanks a lot
Old Jul 30, 2007 | 12:44 PM
Got traction's Avatar
Default Re: dseries built turbo setup how much power can i make? (MBlake55)
youll probibly make 250-300. its hard to tell though my y8 with vitara pistons eagle rods made 210 at 10psi with a stock cat.
Old Jul 30, 2007 | 01:00 PM
evokidvii's Avatar
Default Re: dseries built turbo setup how much power can i make? (trubo97civic)
with that setup you should see any where between 260 to 280. the t28 tops out pretty early, but you will love the powerband it has
Old Jul 30, 2007 | 01:07 PM
bnut510's Avatar
whatever maxes out first.. the injectors or the dinky turb.
Old Jul 30, 2007 | 01:34 PM
CALC!_JUST_du_IT!'s Avatar
Default Re: dseries built turbo setup how much power can i make? (bnut510)
The injectors will definitely NOT max out. 450cc/min is actually overkill for a street driven sohc. 310cc/min would be more appropriate, and easier to tune with. If you wanna be able to run on pump gas, and have a smooth ride, stay around 12-14lbs, you'll get around 230-240whp (which is plenty!!!). If you're tuning for the track, or if you don't care if your motor blows after 15k miles, you can keep it at 15lbs, and make 240-260whp. You won't notice the difference, but your motor will.
MBlake55
Mar 24, 2008 01:15 PM
MBlake55
Jun 8, 2007 07:19 PM
M.A.R.C.
Nov 20, 2003 09:14 AM
SweepeR 7
Oct 13, 2003 07:20 PM
