Radiator Issues.
Radiator issues.
Just installed a Mishoto Radiator w/ Slim fan already welded on. I know its not that hard to install this since theres only 1 screw and 2 tubes and reserve tank but im just making sure. On the fan I had to cut the OEM wires to make them join with the new fan wires.
OEM Wires = 1.Black w/ Red Stripe
2. Solid Black.
Slim Fan Wires= 1. Solid Balck
2. Solid Blue.
So I connected the Solid Black's together and the Blue and Black/Red together.
I turn the car on everything seems to be fine. Let it warm up for about 15 minutes just to see if the temp goes up. Which it doesn't. It stays at normal.
My concern is when does the fan go on?
I want to make sure the fan is working. I thought if you turn the key all the way but not starting it, it goes on. But mine doesn't.
Any help?
2. Solid Black.
2. Solid Blue.
Any help?
no jump start, jump the connector, when you take the connector off stick a paper clip in the 2 holes, then start the key to the on position if your fan comes on wired it right if not try again, make sure its spinning the right way
gl
gl
So just go outside, disconnect the connecter. Stick a paper clip in the two holes and turn key to on with out starting and it should turn on?
If I got that right which way should it spin if sitting in the drive seat. Clock-wise or Counter?
Thanks so much.
Thanks so much.
yeah just make sure you turn the key all the to on you don't have to start. as far as which way it should spin not sure but look at the fan it should spin so that it pulls air if its inside the engine bay, blowing hot air towards the tranny you'll figure it out
I will take pictures tomorrow and post up on here. I like it a lot. I was suprised about the quality. I love how the slim fan is very quiet. Good cheep combo FTW!
Thanks again.
EDIT: This is where I got mine from https://honda-tech.com/zerothread?id=1948360
Thanks again.
socialistic
Sep 10, 2008 03:45 AM
