Radiator Fan / Push or Pull
Old Feb 9, 2009 | 06:38 PM
PhantomX's Avatar
Default Radiator Fan / Push or Pull
Hey, in the process of reviving my car....just picked up a aftermarket radiator fan off the internet and i want to make it a push fan....do i just flip the blades around or do i have to do that and flip the two wires too?
Fan i got looks like this one...
Old Feb 9, 2009 | 06:46 PM
Tony the Tiger's Avatar
Default Re: Radiator Fan / Push or Pull
Some fans are actually reversible just by flipping the two wires... I know most staight blade fans do not need their blades flipped around and all you need is wire them with opposite polarity.
Old Feb 9, 2009 | 06:47 PM
boostedcivicsir's Avatar
Mr. Badwrench
pushers are mounted on the other side of the fan. and have to have polarity reversed so they spin the other way.
Old Feb 9, 2009 | 06:57 PM
PhantomX's Avatar
is there anyways i can hook them up and test? before putting everything back together
Old Feb 9, 2009 | 07:02 PM
Hook it up to a battery, and reverse wires if needed
Old Feb 9, 2009 | 07:07 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
just buy a good fan and you wont need a pusher.
spal-13in fan
Old Feb 9, 2009 | 07:11 PM
spal-13in fan
I thought a pusher is for those who cannot fit a puller fan, due to a topmount, 4" DP, etc...?
If you can fit a puller already on the inside of the radiator (engine side), then there is no point for a pusher on the outside of the rad (bumper side). You don't run two fans on one radiator with the same given space...hah Your above post didn't make much sense to me at least
Old Feb 9, 2009 | 07:24 PM
PhantomX's Avatar
Naa i only going to install one fan.... im removing my oem fan in the engine side because its in the way of my turbo...
Old Feb 9, 2009 | 07:26 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
i wasnt telling him to run 2 fans I sais run a good fan then you don't need a pusher. The Op-never stated he didn't have room. then still in that case i would rather buy the 13in spal pusher. Most people try to make a pusher fan becuase the fan they currently have sucks and can't keep up vs needing it becuase they don't have the room.
Old Feb 9, 2009 | 07:31 PM
JDMCRX's Avatar
A puller fan will always flow more air threw a radiator or condensor.
Watch when you start it up your fingers are out of the way
Old Feb 9, 2009 | 08:39 PM
dpetro1's Avatar
almost lost a thumb that way.
i will also suggest the puller if possible. and the spal 13" works really well
Old Feb 9, 2009 | 09:41 PM
PhantomX's Avatar
so a Puller will actually flow better then a push style set up?
Old Feb 9, 2009 | 10:09 PM
Pusher will always be a last resort, and I think the only reason why we go with a pusher is from the lack of room to run a proper puller setup.
I assumed the OP asked for a pusher, probably because he couldn't fit a puller at the engine side of the radiator.
Old Feb 9, 2009 | 10:46 PM
HiProfile's Avatar
Its not that it flows more air, it just has a better distributed pressure drop over the fins. That all areas to be cooled equally, which increases efficiency. But it doesn't matter much since it has no shroud, and all of 1/4" between the fins and radiator.
The only OEM fans you'll see as pushers are when they have big space issues. The old Probe I got for free had all sorts of useless crap under the hood (I think they called it a Mazda engine ), and the AC condenser was on the front.
Old Feb 10, 2009 | 04:18 AM
redzcstandardhatch's Avatar
something different
i needed a pusher fan due to space constraints, so i bought the BIGGEST i could fit. it actually couldnt fit, and i had to mod the crossmember to fit it. it cools fine, but smaller fans probably wouldnt do it.
get the biggest pusher you can if you need one.
Old Feb 10, 2009 | 05:55 AM
92civiceg9gsr's Avatar
All my cars have pushers just because I wanted to tuck the fan. I noticed no change in temps afterwards.
Old Feb 10, 2009 | 06:41 AM
JDMCRX's Avatar
Yeah me and my buddy were trying to flip the blades around on a spal fan but the blades design put it to close to the rad or condensor. On a hand test i pulled the power away and i think my friend thought the blade was going to opposite ways and try to stop the blades. Well all i heard was a wack and him go UH OH lol. 13 stitches later lol.
Yeah i find the best pusher on a honda rad was a Flex alite fan the 125 series with the shroud the sizes of the rad. If you use one of those cheap fans in front zip tied on i find the fan is on for alonger period and in canada we do not get the honda days you guys get in the usa.
Old Feb 10, 2009 | 08:05 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
i tore my middle finger nail off. now the nail grows wierd and on 1 side
Old Feb 11, 2009 | 12:22 AM
Boosted_B_Series's Avatar
spal 13" ftw! 1700cfms.. thats hard to beat.
Old Feb 11, 2009 | 08:35 PM
berb_15's Avatar
Are all you guys who run the 13" Spal fan talking about this one:
http://www.a1electric.com/Merchant2/..._Code=30102044
and how is it without a shroud, any cooling problems?
and to the OP if you want to test your fan just run your wires to the battery to see which way it spins. Some fans you can just reverse the polarity to get the motor to spin the opposite way (the current flows in the opposite direction) but check the blade design out before you do this to ensure that it will actually push air effectively.
Old Feb 11, 2009 | 09:18 PM
dpetro1's Avatar
yup thats the one. i do not use a shroud and have not had any issues. it turns on at 185 and i havent seen ECTs go higher than that. ive only had the car out in 65* weather so the real test will come this summer when we get some 90* days. if i do have issues im going to try a turbo blanket and fan shroud.
Old Feb 12, 2009 | 02:19 AM
AJxr's Avatar
always had problems running a pusher on a turbo ef, although it was a $50 advance auto electric fan.
Old Feb 16, 2009 | 02:28 PM
PhantomX's Avatar
So i went with the puller... heres a pic to show how much extra room it gave me...enough to finally put on a intake on my turbo...
Old Feb 16, 2009 | 02:54 PM
berb_15's Avatar
looks good man, is that the original fan you were thinking about making a pusher?? I need to buy a fan for my setup here within the next week or two...
Old Feb 16, 2009 | 03:04 PM
PhantomX's Avatar
yea thatz the original aftermarket fan.... theres alot on ebay selling for a good price.
Hobkins
Oct 15, 2012 04:57 PM
Corksil
Dec 9, 2009 06:56 PM
dan200
Mar 22, 2008 07:28 PM
obuhmyuh
Nov 14, 2007 11:18 PM
