Ignition Timing Concern?
Old Jul 28, 2007 | 03:31 PM
mortificationrock's Avatar
Default Ignition Timing Concern?
Hey guys listen up!!! Can anyone tell me how you set ignition timing Please!? I think the guy who said he knew did it wrong just want to confirm cuz car runs like ****! Please if anyone finds the kindness to help i would app. it even though i know this has been covered before THANX
Old Jul 28, 2007 | 04:03 PM
Default Re: Ignition Timing Concern? (mortificationrock)
ANYONE PLEASE???
Old Jul 28, 2007 | 04:38 PM
BUMP
Old Jul 28, 2007 | 05:11 PM
egsleepercivic's Avatar
get a timing light, get your car to operating temp, shut off car, jump the service connector, loosen bolts on dizzy, connect timing light to battery and #1 spark plug wire, start car, aim light at crank pulley line up the white mark with the pointer on timing belt cover for stock timing, adjust to red mark for +2*, ( you adjust by turning dizzy), when desired timing is set tighten bolts on dizzy double check timing, shut off car remove service jumper, go rip mad vtak y0!
gl
Old Jul 28, 2007 | 05:29 PM
RiversideS13's Avatar
Default Re: (egsleepercivic)
is the service connector as the CEL code plug (2 wires)??
Old Jul 28, 2007 | 05:37 PM
thats it, same one you jump to check codes
Old Jul 28, 2007 | 06:04 PM
Thanks for help but i still cannot get it to work.
when i look at the mark, i see 4 6 1 I and the white pointer thing down there (as circle by red color)
however, when i turn the dizzy, the 461 I sequence just moving along the range as i marked by blue. what should i do now? and where is +2?
Old Jul 28, 2007 | 06:14 PM
its on the crank pulley not the cam pulley, I suggest you get some sort of manual, helms would be best. i don't know if haynes or chiltons will show you how to set the timing or not. if you sgn up at hondahookup.com I believe they have manuals you can download
gl
Old Jul 28, 2007 | 09:35 PM
thanks for pointed out. i have a service manual for accord and 240sx which shows i should see the pointer on top of the pulley. but on this d16, i dont see ****. can anyone would so kindly show me where is it? is it possible it just gone?
EDIT: i figure out why i cannot see ****. the damn engine does not have timing belt cover
Modified by RiversideS13 at 1:44 AM 7/29/2007
Old Jul 28, 2007 | 09:48 PM
Default Re: (RiversideS13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiversideS13 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for pointed out. i have a service manual for accord and 240sx which shows i should see the pointer on top of the pulley. but on this d16, i dont see ****. can anyone would so kindly show me where is it? is it possible it just gone?</TD></TR></TABLE>The marks there on cam is for cam timing only! The word up is suppose to stay up while the mark on the side align with the mark on the side of the head and the line with the bottom pionter!!! My question is ignition timing as in ignition not general timing of cranks!
Old Jul 28, 2007 | 09:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">get a timing light, get your car to operating temp, shut off car, jump the service connector, loosen bolts on dizzy, connect timing light to battery and #1 spark plug wire, start car, aim light at crank pulley line up the white mark with the pointer on timing belt cover for stock timing, adjust to red mark for +2*, ( you adjust by turning dizzy), when desired timing is set tighten bolts on dizzy double check timing, shut off car remove service jumper, go rip mad vtak y0!
gl </TD></TR></TABLE>What degree do you set the TDC to? I mean when checking white mark at what degree is the timing gun suppose to be set at? Some dude said 0* degrees and that at 16* im suppose to see red marks is this true?! Thats how it was done was it done wrong if so please someone help me fix this!! My car would be thankful for it
Modified by mortificationrock at 11:09 PM 7/28/2007
Old Jul 28, 2007 | 10:06 PM
Syndacate's Avatar
Cam timing is different from dizzy timing.
Cam timing makes sure your cams are in sync with your crank.
Dizzy timing makes sure it's firing at the right time.
For the "UP" on the cam pulley, that's for cam/crank timing, not dizzy timing, so you can set the timing when you're putting on a timing belt.
As far as setting the timing for the distributor, use a timing light.
You don't need any special tools to check the cam/crank timing. Just put a LONG screw driver in the #1 spark plug hole and turn the engine until the handle is as high as it will go (before it starts going back down) - now it's at TDC. Then you set the cam to TDC by pointing the cam so that "UP" is up or if it has a hash on each side, so that it's even w/ the head...or if it's a DOHC and it's got 2 arrows, that they're pointing at each other...so on and so forth.
Old Jul 28, 2007 | 10:11 PM
Default Re: (Syndacate)
Yeah thanx but im asking about ignition timing as in dizzy timing. how do you set that correct the other guy thread jacked me!! Hes the one that is wondering about crank timing not me i need ignition timing and need to know what to degree to set my timing gun at when checking for marks and which marks am i looking for?
Old Jul 28, 2007 | 11:34 PM
BUMP CUZ I NEEDZ HELP
Old Jul 29, 2007 | 06:36 AM
you need to at least tell us what car motor you have
Old Jul 29, 2007 | 08:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">you need to at least tell us what car motor you have</TD></TR></TABLE> I have a 93 honda civic lx w/ JDM D15B Vtec engine!! Any Help?
Old Jul 29, 2007 | 09:34 PM
I don't know the specs for that motor, but I believe if you leave it a zero you can just line up the red or white mark. not 100% on that though
Old Jul 29, 2007 | 10:57 PM
SiRkid's Avatar
bah just start er up..play with the distributer till it idle decently. lawls thats what i did with mine like 2 years ago and I havent touched it since. car trapped 93 mph . lol not bad
northemt88
Mar 15, 2008 12:57 AM
civic j
Aug 17, 2007 08:10 AM
NSfit
10
Nov 14, 2006 11:17 AM
Fat Chick Magnet
Aug 4, 2006 02:02 PM
DieMaster
Jul 2, 2004 09:09 AM
